Another Cooling fan problem
I dont get the high speed fans on either side but I do get the low speed fan on th drivers side. I jumped the wires to the thermo switch, low speed fan on drivers side comes on, turn key to on position still only get low speed. I can turn on the a/c and still no high speed fans with key in on position.
Sometimes they will come on after the low speed fan has been running for quite some time but usually not untill the car is heated to the 3rd line on the temp gauge and i dont want to it overheat. I think a relay is getting stuck or maybe a loose wire. I dont know which relay accually goes to the coolant fans cause everywhere you look says something different.
1984 944 NA 5spd Last edited by Majin325; 04-24-2009 at 02:03 PM.. |
It's either the fuse or the relay. Check the owner's manual. It shows a photo of the relay locations.
