removing release lever pivot shaft??
According to Clarkes, I need a 8mm x 150mm bolt to remove this. The problem is I can't find this size bolt at my local hardware store. Is there a universal tool that I can rent at my local autoparts store? Any other way of removing this?
Thank you. |
meister member
The shaft has a threaded hole in the end. I thread a screw in the hole and use my slide hammer to tap it out. Make sure to have the setscrew taken out before you try to remove the shaft.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
In the Fires of Hell.....
I just used the longest bolt I could find at the local Ace store.
It was long enough.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Custom User Title
The one I use is only about 4". I screw it in, then clamp onto it with vise grips, and then beat on the vise grips with a hammer. Works like a charm.
83 944 NA - Black on black 86 951 - Red - SOLD 7/21 16 Ford Expedition He who hesitates is lost. |
