Ideas for brake upgrades on 84 944?
One of our clients has an early 944 and looking to upgrade to larger brakes. Has anyone here done something different than a turbo upgrade to their car? There is not much available commercially (understandable since most kits would outvalue the car!) and even VCI (one of the best places for brake adaptor set ups) has nothing.
the client is looking for larger calipers and rotors. I probably could do something with boxster calipers , adaptors, but would prefer to find something semi- off the shelf
thanks!
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 05-30-2009, 04:17 PM
That Guy
Techno Duck's Avatar
Rennbay.com makes a bolt on setup that uses Wilwood calipers. It however does not use larger rotors, same as stock.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 05-30-2009, 05:03 PM
Aslet's Avatar
Tell your client that the 944 is a momentum car, so use less brakes and carry speed (I assume he is tracking)!
I second Techno Duck, the only bolt-on kit is the Wilwood front calipers...
-Randy
1984 944 -Race car project
1993 968 coupe- Amazon Green
Old 05-30-2009, 09:10 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Wilwood is good. Otherwise change to 951 spindles and big blacks (or big reds if you like spending lots of money - the good news is they'll work with the 951 spindles).
Black Cars Matter
Old 05-30-2009, 11:39 PM
WestonP22's Avatar
Yup. It also already has more brakes than it needs... if you have an issue with brake performance on the track, then you just need fresh fluid and appropriate pads for what you're doing. There's no sense in increasing rotating mass (ie larger rotors), as it will only decrease performance. Our 11" rotors are huge for cars that only have 160 HP, especially when you consider that we really don't need to slow down much for turns.
#22 RaceRender.com Porsche 944
Old 06-01-2009, 07:29 AM
aftermath's Avatar
renegade hybrids sells a kit for under $3000, dont know much else about it
$2,950 944 "BIG RED" BRAKE UPGRADE KIT: Complete with 993 twin turbo four piston calipers and new pads, caliper adapters, 993 turbo rotors, custom brake lines, used late model turbo struts and hubs, 928 proportioning valve, and hardware.
theamsoilguy@hotmail.com
Old 06-01-2009, 12:54 PM
Aslet's Avatar
I know Lindsey Racing also sells the Big Red kit, but it is only for 951's. Just be careful its designed for a NA 944...
-Randy
Old 06-01-2009, 04:57 PM
Check out the Porsche Hybrids website. We've come up with a great combination for our higher HP cars - Boxster S rotors with Lexus 4-piston monoblock calipers on the front, 951 rotors/calipers on the rear.
Old 06-02-2009, 04:52 AM
