Tow points
![]() My question is: Where would you hook up to tow the car from the front and from the back, if necessary, without damage to the car? |
There are two hooks down by the front sway bar
#22 RaceRender.com Porsche 944 |
Weston - are those hooks only on early cars? I didn't see them on my '88 when I was in the same boat, and we ended up winching the car onto the bed of the truck using a nylon strap around the front control arm.
In early cars, you can probably get away with using the steel hooks which tow truck drivers have on their winches since the control arms are steel, but it would still make me a little uncomfortable. The rear is especially tricky. I ended up pulling mine backwards with the same nylon strap run below the rear trailing arm and around the torsion bar end, and I don't really recommend this. The next day, I bought a tow hook online.
Charlie '99 996 C2 6 speed - Arctic Silver |
Greasy Member
Shouldn't make a difference between early and late. All of these cars originally had "tie down" eyelets at the front and rear of the car, it was required for import into the U.S. in fact, that is how they were strapped to the boat on the way over!
I have seen several of them bent 90 degrees (parallel with ground) and I've even seen some of them cut/torn off. Afterall, thay are getting up there in age! -Nick
Owner: Bennington Motorsports www.benms.com Sponsor for Midwest Region 944-SPEC racing series -When was your timing belt changed or tensioned?? -Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP. |
Tie down
I'm sure they are tie downs for shipping. I don't see any hooks at all for the back. Guess I'll have to fabricate some of my own! I have seen some Porsche "tow hooks" on ebay. Has anyone used these? What do they bolt to? |
I towed my car (maybe 3 miles) and I think I used the eyelets that many944's is talking about. Does anyone have any pictures of these? Right in front of the A-arm, correst?
For the rear, I can picture in my head any eyelets in the rear. Have used a flat bed everytime. I think someone said that there are poles in front of the rear tires (torsion bars?) that can be used for towing, or to hook up for a flat bed.
Steve- If you havent looked, look- www.clarks-garage.com 87 951 red- Maria (current) 84 944 white- Percilla (current DD) 85.5 944 red- Pinta (past) 87 924S red- Nina (past) |
Army Wrench Turner
There are bolt on eyelets the go straight to the frame rails. These are ideal and required for things like Targa Newfoundland. I had to be recovered a while back and the wrecker crew used a pair of J-hooks linked in a Y-yolk hooked onto the torsion bar anchors to drag me onto the flatbed.
The anchors are in the rear wheel wells in front of the wheel. about an inch diameter and 5 inches long from the frame if memory serves. It's a solid drag point so long as they use a Y-yolk and not try to drag with a single hook. Then it's just dangerous lol.
- '84 944 (Black) |
Greasy Member
True, the spoiler does flex a couple inches, but I have never seen it actually damage it. and I have had several of these towed to my shop over the years.
It's good to know local tow truck drivers, especially when someone askes them "do you know of anyone around here that even works on these" ![]() Quote:
Army Wrench Turner
I forgot t mention... I have the "Euro" front spoiler. I've only ever seen it on a car in the *********** catalogue. The Crew hooked through the lower outside intakes to the frame. We had to ragpad the spoiler but nil damage on the fiberglass nose piece.
- '84 944 (Black) |
![]() just being a smartass ![]()
84 Red 944 NA - Das Swurvenwagen - still street legal but it's just a track toy My Website: http://www.TrackPics4Less.com |
