Tow points
I recently needed a tow for my '83 944 due to a starter failure. The tow truck driver would not pull the car up onto his truck because he could not find a place to connect his chains to the car [trying to pull rear of the car up first]. Turns out it did not matter because we started the car with a short push backwards and bumping the clutch with the trans in reverse.
My question is: Where would you hook up to tow the car from the front and from the back, if necessary, without damage to the car?
Old 05-29-2009, 07:52 AM
WestonP22's Avatar
There are two hooks down by the front sway bar
#22 RaceRender.com Porsche 944
Old 05-29-2009, 07:56 AM
pontifex4's Avatar
Weston - are those hooks only on early cars? I didn't see them on my '88 when I was in the same boat, and we ended up winching the car onto the bed of the truck using a nylon strap around the front control arm.
In early cars, you can probably get away with using the steel hooks which tow truck drivers have on their winches since the control arms are steel, but it would still make me a little uncomfortable. The rear is especially tricky. I ended up pulling mine backwards with the same nylon strap run below the rear trailing arm and around the torsion bar end, and I don't really recommend this.
The next day, I bought a tow hook online.
Charlie
'99 996 C2 6 speed - Arctic Silver
Old 05-29-2009, 09:23 AM
Greasy Member
many944s's Avatar
Shouldn't make a difference between early and late. All of these cars originally had "tie down" eyelets at the front and rear of the car, it was required for import into the U.S. in fact, that is how they were strapped to the boat on the way over!
I have seen several of them bent 90 degrees (parallel with ground) and I've even seen some of them cut/torn off. Afterall, thay are getting up there in age!
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 05-29-2009, 01:41 PM
Tie down
-Nick
Yes, my car has these "hooks" at the front, but I wouldn't try to tow with them because of potential damage to the front spoiler, A/C hoses and other components.
I'm sure they are tie downs for shipping. I don't see any hooks at all for the back.
Guess I'll have to fabricate some of my own!
I have seen some Porsche "tow hooks" on ebay. Has anyone used these? What do they bolt to?
Old 05-29-2009, 03:24 PM
thekidd's Avatar
Send a message via AIM to thekidd
I towed my car (maybe 3 miles) and I think I used the eyelets that many944's is talking about. Does anyone have any pictures of these? Right in front of the A-arm, correst?
For the rear, I can picture in my head any eyelets in the rear. Have used a flat bed everytime. I think someone said that there are poles in front of the rear tires (torsion bars?) that can be used for towing, or to hook up for a flat bed.
Steve- If you havent looked, look- www.clarks-garage.com
87 951 red- Maria (current)
84 944 white- Percilla (current DD)
85.5 944 red- Pinta (past)
87 924S red- Nina (past)
Old 05-29-2009, 03:59 PM
Army Wrench Turner
Ctan's Avatar
There are bolt on eyelets the go straight to the frame rails. These are ideal and required for things like Targa Newfoundland. I had to be recovered a while back and the wrecker crew used a pair of J-hooks linked in a Y-yolk hooked onto the torsion bar anchors to drag me onto the flatbed.
The anchors are in the rear wheel wells in front of the wheel. about an inch diameter and 5 inches long from the frame if memory serves. It's a solid drag point so long as they use a Y-yolk and not try to drag with a single hook. Then it's just dangerous lol.
- '84 944 (Black)
Old 05-29-2009, 04:04 PM
Greasy Member
many944s's Avatar
True, the spoiler does flex a couple inches, but I have never seen it actually damage it. and I have had several of these towed to my shop over the years.
It's good to know local tow truck drivers, especially when someone askes them "do you know of anyone around here that even works on these"
Old 05-29-2009, 04:43 PM
Army Wrench Turner
Ctan's Avatar
I forgot t mention... I have the "Euro" front spoiler. I've only ever seen it on a car in the *********** catalogue. The Crew hooked through the lower outside intakes to the frame. We had to ragpad the spoiler but nil damage on the fiberglass nose piece.
- '84 944 (Black)
Old 05-29-2009, 07:01 PM
944Spec_bound's Avatar
just being a smartass
84 Red 944 NA - Das Swurvenwagen - still street legal but it's just a track toy
My Website:
http://www.TrackPics4Less.com
Old 05-29-2009, 07:34 PM
