-   -   Engine Drop - Remove Head First For Extra Clearance? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/477889-engine-drop-remove-head-first-extra-clearance.html)
OK-944 06-03-2009 05:34 AM
This sounds so obvious...but I have not seen this mentioned - that to gain some extra clearance for an engine drop I may as well just remove the head first - make sense?
krystar 06-03-2009 06:13 AM
u could, but it's not needed. as long as you the 21 inches clearance, you're fine.
follow
http://www.clarks-garage.com/shop-manual/eng-01.htm
944 Ecology 06-03-2009 07:44 AM
Just remove the distributor cap and rotor and the radiator fans, and you should have plenty of room.
exitwound 06-03-2009 08:28 AM
I had to remove the oil filter to get another 1/2" to 1" on the right side just to be safe.
Schumi 06-03-2009 08:48 AM
If you remove the dist. cap, also remove the rotor. I didn't and when lowering the engine out, I bumped it into the radiator crossmember and it chipped the rotor. They aren't cheap.
onZedge 06-03-2009 04:51 PM
I would remove the radiator (you never know) - they aren't cheap either.
Arizona_928 06-05-2009 07:15 PM
I wouldn't as the studs go up to just about the same height. If you need acouple inches a block of wood works well.
speedracing944 06-05-2009 07:17 PM
drop it with the head. Remove radiator as others have suggested.
Speedy:)
