rabarrer's Avatar
Un-Clog Washer Nozzle??
just replaced all of the hoses for the windshield washer in hopes of freeing a clog that prevents the water from getting to the windshield.
it is now obvious that the sprayers are clogged
is there an easy way to clean tham out?
thanks
Old 06-05-2009, 05:55 AM
Carefully poke at them with a sewing needle until all the gunk is worked out (probably wax), then flush then with washer fluid.
Rick
93 968 (My summer car),
05 Cayenne S (My winter car),
79 924 (Wife's summer car), 02 C230k (Wife's winter car),
Old 06-05-2009, 06:52 AM
bearone2's Avatar
i unhooked the hose at the pump and back flushed with controllable nozzle on a garden hose.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 06-05-2009, 07:55 AM
gpotts200's Avatar
I used simple green in the nozzle and left it soak for 30 minutes.....then used an air compressor to force air through the nozzles. I shot out a lot of black sludge.....then the washer pump was connected an it works fine....a needle can be used to adjust the spray location on the window.
1984 Guards Red Porsche 944 NA
2005 Suzuki Forenza
2005 Suzuki SV650 **SOLD**
2008 Toyota Siena
Old 06-05-2009, 08:35 AM
The L and T-shaped check valves can also go bad, I just had to replace one of mine.
Grant
89 951
Old 06-05-2009, 01:03 PM
