-   -   no spark ...problem (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/478588-no-spark-problem.html)
gibson36 06-07-2009 08:57 AM
no spark ...problem
ok so my 944 sat 4 about 3 years and now i got no spark Im thinking dme relay is there anything else I shold be looking at ? ? ( side note I get a ground at the coil when the car is off but I don't get a pulse when I crank nore do I hear the fuel pump kicking on )
krystar 06-07-2009 09:36 AM
dme relay is first thing since u don't get fuel
John_AZ 06-07-2009 10:12 AM
Just to ask, did you drain the tank of old fuel first, change the dried out filter and crossed your fingers the injectors have not gummed up with dried fuel varnish?
GL
John_AZ
1988 924S + 1987 924S
gibson36 06-07-2009 10:57 AM
GL
John_AZ
it was put away the right way should be all good if i can get spark and fuel ....lol
John_AZ 06-07-2009 11:48 AM
OK, Good to hear.
Good information on "Engine Storage" about 3/4 down. Terry Shugert and Herr Klaus Fischer will tell you how to prepare the engine for startup.
http://www.porschenet.com/winter.html
This will not solve your problem, only give you a good engine when you solve the no-start.
You could also just make a DME relay "jumper" outlined in www.Clarks-Garage.com to test.
GL
John_AZ
gibson36 06-07-2009 05:02 PM
Originally Posted by John_AZ (Post 4707838)
OK, Good to hear.
GL
John_AZ
cool thanks
