-   -   Want to convert to A/C 134A ? Any Ideas?? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/479091-want-convert-c-134a-any-ideas.html)
John_AZ 06-21-2009 05:39 PM
Freeze 12 is highly debatable. Here is one entry that makes sense.
"Freeze 12 has it's own set of issues.
Since it's a refrigerant blend it must be charged as a liquid - and over time the components will leak out of the system at different rates. If future repairs are needed on the system you will need to find someone with recovery/recycle equipment that is dedicated to Freeze 12. Most shops will not work on any A/C systems that are not R12 or R134.
IMHO it's not worth the trouble to use non standard refrigerants but if you must please use the correct service fittings that are specified for Freeze 12 conversions to alert future owners and technicians that your car is fitted with a non-standard refrigerant. For Freeze12 you are supposed to use a 7/16 diameter left handed 14 pitch thread connection for the high-side service port and a 1/2 inch right handed 18 pitch connection port for the low-side service port."
Time will be the judge. The next owner may find one more surprise. :mad:
GL
John_AZ
mattdavis11 06-21-2009 07:33 PM
Do what you want. Charge on the high side, use Freeze 12, I don't give a ****. Mine is still cold and cycles on 134. Thoen, think about it.
thoen 06-22-2009 06:34 AM
matt,
thanks for not giving a s""t!! You rock!!
send me the paypal bill, ok?
i will give freeze 12 a try and i will changeover to 134 if it doesn't work out. IT'S AN EXPERIMENT!!
you have given all of us some great A/C info!!!
mattdavis11 06-22-2009 08:48 AM
I've never sent an invoice through pay pal. Trying now. I'm clueless on the shipping, I've no idea where to send the compressor or through which carrier, an obviously have zero idea how much it'll be. I guess I'll bill that later?
John_AZ 06-22-2009 09:02 AM
I get starters and clutch parts with USPS FLAT rate boxes. Weight does not matter. Fill it with old bolts and shop bling to make it even heavier. ;)
GL
John_AZ
jackrussell 06-22-2009 09:21 AM
Originally Posted by nightheart (Post 4712770)
If your changing over an early 944 compressor, than you need to run a shorter alternator belt and use a 90 degree adapter for the low side port.
What is the reason for using a shorter alterrnator belt?:o
Tom.
mattdavis11 06-22-2009 09:32 AM
so it'll clear, a straight R12 to 134 fitting won't work with either the shorter or a regular length belt. A 90 degree fitting and a shorter belt is the way to go if you plan to convert to 134.
Thunder-71 06-22-2009 08:49 PM
Originally Posted by John_AZ (Post 4735415)
Now the opposite position................
Thunder-71,
:D Why do you need AC at all? You live north of Buffalo NY and maybe get to 90 degrees once year. :)
My 1998 Jeep Cherokee has R-134a and I have no problem when it is 114+ in AZ--next week. My refrigerator-Magic Chef by Maytaq is filled with R-134 and the freezer works, actually too cold, the ice cream is too hard.
I will be using R-134a in my '87 924S this summer when I convert. I am going to go GREEN and save the planet.
In AZ we can go to old Mexico and pick up R-12. Actually no one is sure what is in the can and it could be pure propane or tequilla.
I see you have been buying a lot of parts for your '84. Will you be replacing the receiver/dryer? Vacuum and recharge? Is the seal on your compressor still good or do you see a black racing stripe on the underside of the hood or the engine pan? Your R-12 could last you one or 2 seasons.
GL
John_AZ
1988 924S + 1987 924S
Hello John,
You helped me in the past few weeks on issues I had with my 944 and I appreciate it. Your comments on R12 are correct as far as GREEN for the Planet but R12 is less than the tip of the iceberg, we need to do a lot more than that. I may not need the A/C here in Buffalo as much as you, but I still need it. This car is going to Europe to be my vacation/fun car and the A/C is a must there. The parts I am collecting are actually spare parts that will go with the car. Yes I know Porsches are European/German cars, but parts outside of Germany are tough to find and very expenssive. We are spoiled here. I am an American Muscle Car guy (I own 3 Plymouth Cudas) and know very little about Porsches. Any suggestions as to what spare parts should I take that are most likely to need replacement or usually ware out? I have no plans to replace the receiver/dryer and maybe I should. If the systems gets opened it gets contaminated I think?
Regards, George.
John_AZ 06-22-2009 09:48 PM
Hi George,
I am scratching my head trying to understand why you would want to ship a 944--back to Europe. Why don't you take one of the Plymouth Cudas? I've been to a few European car shows and American muscle cars have a huge following. Really big in the UK.
As far as parts, a lot Porsche parts are made or reproduced in Europe. Maybe expensive but available. With USPS international Priority mail, Pelican will ship what you need ;).
Parts? OK, he needs AC and it will be hot. "Part-time vacation fun car". Now you do know that with a 25 year old Porsche that is not possible. Leave the Porsche in the US and just rent a car for the track. Let someone else do the work.
Enjoy Europe.
http://www.pff-online.de/wbb2/index.php?sid=ad6fff77a03cb20e1c812267642fa7c3
GL
John_AZ
jackrussell 06-26-2009 04:20 PM
Shorter belt
Is the shorter belt a standard length? What length is it? Anyone have a part number?
Tom.
mattdavis11 06-26-2009 04:30 PM
The shorter belt, by 1 inch, is 39.00 inches. Autozone has them. 5 rib belt. Give me a minute and I'll find the part # for you Tom.
Gator backs
Part number: 4050395 This is a 1/2 inch shorter
Part number: 4050400 This is stock
Part number: 4050390 This is what you want if they have it
Duralast belts
Part number: 395K5 This is a 1/2 inch shorter
Part number: 400K5 Stock belt
Part number: 390K5 This is what you want if they have it.
jackrussell 06-26-2009 04:48 PM
Gator backs
Duralast belts
Thanks Matt. I think I have all the required information now. SmileWavy
Tom.
mattdavis11 06-28-2009 07:05 AM
Ahh! 85 degrees out this morning (there must have been a cool front roll through) and the vent temps dropped to 35 degrees while driving 60mph before it cycled off. I have to mess with the pressures this afternoon because there is no way it was blowing that cold yesterday when it was 105 outside.
thoen 07-08-2009 10:41 AM
ac
i have a problem:
1. i plugged the connector into the input by the compressor.
2.i then turned the knob on the refridgerant, the ac was running full blast and the refridgerant can became a popsicle.
3. i let it run for ten minutes and felt no change inside of the car.
4. i figuered it was through. i released the hose and closed the knob on the can.
the can was a bit cold but not like before. i removed the hose attachment from the can and refridgerant blasted into the air and the can became frozen again.
i don't think anything went into the ac system.
what did i do wrong????
:confused:
