-   -   Rear main seal is not seated all of the way...will I have problems if... (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/479371-rear-main-seal-not-seated-all-way-will-i-have-problems-if.html)
shogunther 06-10-2009 06:50 PM
I just installed the RMS and I ran my finger around the block bevel and part of the seal (very very little) is barely sticking out. Is this acceptable? When I install the flywheel will it push it back in? Could this cause the RMS to leak? I slammed this thing a million times with a rubber mallet and it wont go in anymore.
kdjones2000 06-11-2009 05:55 AM
Yes, it will leak.....
Get a 4" capped drainage pipe and use that to set it in. There is another thread going on right now about this same thing with a good picture of a RMS set properly.
