Rear main seal is not seated all of the way...will I have problems if...
I just installed the RMS and I ran my finger around the block bevel and part of the seal (very very little) is barely sticking out. Is this acceptable? When I install the flywheel will it push it back in? Could this cause the RMS to leak? I slammed this thing a million times with a rubber mallet and it wont go in anymore.
Old 06-10-2009, 06:50 PM
In the Fires of Hell.....
kdjones2000's Avatar
Yes, it will leak.....
Get a 4" capped drainage pipe and use that to set it in. There is another thread going on right now about this same thing with a good picture of a RMS set properly.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 06-11-2009, 05:55 AM
