Crank posistion sensor 2 ? ?
so if I want to replace mine do I have to replace both or witch one is the Crank posistion sensor ? ? 1984
1 comes out real easy the other is not budging
Old 06-10-2009, 04:51 PM
Greasy Member
many944s's Avatar
The crank position sensor is the one nearest the engine, the speed sensor is the one located nearest the firewall. If they have never been removed or replaced they can be a real PITA to get out! Do be cautious!! I have seen several of the aluminum brackets that hold both sensors snap because too much force was applied to try to remove them!
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 06-10-2009, 05:59 PM
good thats the one that came out no problem ..lol thanks
Old 06-10-2009, 10:30 PM
