-   -   Cold start system (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/479923-cold-start-system.html)
markt944 06-14-2009 08:36 AM
Cold start system
Any body explain how the cold start system works on an 89 s2 ?includeing location of compoments
Thanks Mark
944 Ecology 06-14-2009 10:19 AM
Injectors fire for longer, making it run richer.
John_AZ 06-14-2009 11:17 AM
The DME computer and the coolant temperature sender work together.
www.Clarks-Garage.com has testing info.
http://www.clarks-garage.com/pdf-manual/elect-19.pdf
GL
John_AZ
markt944 06-14-2009 12:16 PM
Ok thanks ,how do u know if the auxillery air valve is working? will the revs go up on a cold start? if its not working will it effect cold start or just cold running?
Thanks again Mark
944 Ecology 06-14-2009 12:19 PM
On a 944S2, there is no auxiliary air valve. There is a Digital Idle Stabilizer, which will do its darndest to keep the revs at 900-1100 rpms, regardless of temperature.
If the DIS is not working, it will only affect idle speeds, and you may see variations, either high or low, depending on where it's failing.
markt944 06-14-2009 12:32 PM
Are u sure thats right ?,bare in mind mines a European model ,theres a canister inbetween number 1 and 2 cyl on intake manifold with an electrical connector going to as well as being connected to the air intake system
Mark
944 Ecology 06-14-2009 01:25 PM
Sure... wanna make a bet?
Ga 951 06-14-2009 09:45 PM
DO NOT take the bet, George knows his stuff !!!!!!!!!
Razorback1980 06-15-2009 01:07 PM
I agree, don't take that bet unless it's not the original motor!
