Cold start system
Any body explain how the cold start system works on an 89 s2 ?includeing location of compoments
Thanks Mark |
Injectors fire for longer, making it run richer.
Good luck, George Beuselinck |
Proprietoristicly Refined
The DME computer and the coolant temperature sender work together.
www.Clarks-Garage.com has testing info. http://www.clarks-garage.com/pdf-manual/elect-19.pdf GL John_AZ |
Ok thanks ,how do u know if the auxillery air valve is working? will the revs go up on a cold start? if its not working will it effect cold start or just cold running?
Thanks again Mark |
On a 944S2, there is no auxiliary air valve. There is a Digital Idle Stabilizer, which will do its darndest to keep the revs at 900-1100 rpms, regardless of temperature.
If the DIS is not working, it will only affect idle speeds, and you may see variations, either high or low, depending on where it's failing.
Are u sure thats right ?,bare in mind mines a European model ,theres a canister inbetween number 1 and 2 cyl on intake manifold with an electrical connector going to as well as being connected to the air intake system
Mark |
Sure... wanna make a bet?
DO NOT take the bet, George knows his stuff !!!!!!!!!
Bruce P. 2011 Cayman Base, LSD, Sport Chrono. 1988 951 totaled and missed ![]() "You're the best I ever had" --JJ Cale |
I agree, don't take that bet unless it's not the original motor!
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
