-   -   Converting Early Car to Removable Trans X-Member (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/479926-converting-early-car-removable-trans-x-member.html)
Rasta Monsta 06-14-2009 07:46 AM
Anyone done this?
944 Ecology 06-14-2009 09:18 AM
I'm sure you have a good reason to want to do this, but for the life of me, I can't figure out why?
Installing a plastic tank?
mvallee 06-14-2009 04:27 PM
If your doing this to your 924S, the bolt holes with nuts welded to inside of frame are alreay there, just need to cut out crossmember.
Rasta Monsta 06-14-2009 07:55 PM
George, yes, plastic tank and late tranny.
mvallee, I am intrigued, where did you come by this info??
mvallee 06-15-2009 03:13 AM
I'm converting a 924S to 924 GTS replica with 951 drivetrain, suspension, brakes, plastic tank. I cut the crossmember out and was prepared to cut open the frame to weld in the nuts but everything is already there.
Rasta Monsta 06-15-2009 06:48 AM
Cool, don't suppose you snapped any pics of the surgery?
mvallee 06-15-2009 07:11 AM
i can get some, im about to prime the underside.
Rasta Monsta 06-15-2009 11:51 AM
That would be fantastic, thankee!
mvallee 06-16-2009 04:42 PM
Here's a couple pics of the frame rails and the two standoffs for the plastic tank. I didnt get pics of the tank strap brackets, let me know if you need those too.
http://forums.pelicanparts.com/uploa...1245199291.jpg
http://forums.pelicanparts.com/uploa...1245199313.jpg
http://forums.pelicanparts.com/uploa...1245199326.jpg
Rasta Monsta 06-17-2009 10:16 AM
Ah, so the standoffs and strap brackets were cut from the donor car?
mvallee 06-17-2009 10:51 AM
They were, you might get away without the standoffs but the strap brackets are needed. The late straps do bolt to the existing holes in the frame.
Rasta Monsta 06-17-2009 05:27 PM
OK, so do the standoffs sit in the indentations on top of the tank, maybe to keep it from slipping back and forth?
http://i124.photobucket.com/albums/p...rg/futanka.jpg
How important do you think that is? I realize it will be quite heavy with all that extra dino juice inside. . .
mvallee 06-18-2009 03:46 AM
Yes, thats where the standoffs fit.
The staps hold it in there pretty well, but I suppose Porsche had their reason to put them there.
You'll also need the puel pump bracket held in by the passenger side tank strap and a later connector for the sender, brackets for standoff bolts.
Feel free to contact me offline if you need any other info.
