OK you guys really helped me to get the collar on _Thank you very much for your advice. But I think I might now have a major problem. - I finally got the collar on but when I moved the CV joints (clutch fully depressed) the drive line did not move?? When I put the car in 1st (and the clutch is dis-engaged) the drive line will not budge and when the clutch is engaged in gear and out the wheels and CV's/wheels move freely but the drive-line does not spin. Is my rebuilt transaxle the problem or should I just go to bed and stop rambling like a fool?
Back from Beyond
Hmm. Maybe have someone rotate the engine from the crank bolt at the front. 24mm socket and breaker. Then crawl underneath and see what moves.
Congrats on the coupler!
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
Back from Beyond
Drat! Double post.
Will program for food
I know this must not be it - but you did release the hand brake, right?
If so a little more info might help. Year, LSD?
Greg Hnat 87 Targa Disassembled 90 944 S2 Auto-x, DE and semi-daily driver 98 Jeep Cherokee |
Problem Solved!!!! The Silver Bullet runs Wild!!
Thanks guys.. I just Slipped into 1st and depressed the clutch and the drive line turned freely..
![]() The car runs great!! I'll post some pictures.. Dan |
