oprv spring shimming?
I read that these springs get weak and u can shim it to get it to keep better pressure.
but how do i get to the spring to shim it?
i did a test drive last nite after seeing oil pressure not climb past 3 when revving. i did notice the described behavior that when i accelerate, the oil pressure drops like 1/4 bar or so indicated. not really big amount, but noticeable on the guage.
so yea...i wanna get to shim the spring
Old 06-25-2009, 07:36 PM
Just thinking out loud
mattdavis11's Avatar
I have no idea, but am curious if you have the shimming confused with the 3 piece oprv that the early cars have. I can see how those can be shimmed, but not the one you have, and at $300 a pop, I'm not sure I'd have the balls to find out.
91 FJ80
84 Ram Charger (now gone)
Old 06-25-2009, 07:54 PM
i read the post from clark garage that he talked about shimming his S2...so i was guessing it wasn't exclusive to the early 3 piece....
Old 06-25-2009, 07:59 PM
Schumi's Avatar
The threaded gold cap pulls off the valve body. It is pressed on there with an O-ring holding it on. It is a tight fit but you can pull it off, inside is the spring.
M
Old 06-25-2009, 08:15 PM
Be careful when you do this. You have to be absolutely sure the problem is the OPRV.
I shimmed the OPRV with a 0.8mm flat washer instead of buying a new OPRV. I did it after confirming that my new oil pressure sensor was calibrated right as confirmed by bench testing it using regulated compressed air and I am still only getting 3.8 bars at 4k rpm. I concluded that the OPRV spring is getting weak.
This is how I bench tested the sensor.
Can anyone a good uninstalled oil pressure sender check something for me?
[url]
You should be able to separate the body from the hex part. There is an o-ring sitting on a groove inside the hex part. Mount the hex part on a vise and pull the body away from hex part. It should come apart. You will see the spring inside.
The green sketch is the washer location.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 06-25-2009, 08:27 PM
thanks schumi! got it apart, put a washer in. putting that back together was a whole lotta fun hheh. oprv is back in the car and i'll finish up tomm and see if it helped any.
thanks!
Old 06-25-2009, 09:48 PM
