-   -   Simple Front End Toe Alignment (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/481781-simple-front-end-toe-alignment.html)
LifterEyes 06-23-2009 09:05 PM
Hi All,
I have to replace my steering rack and am trying to find some tips or a guide to readjust my front end toe after I reinstall the new rack. Can anyone offer a guide, link, or some tips on how to do a front end alignment for the toe adjustment only? I plan on replacing my struts eventually but at that point i will bring it in to be professionally done.
krystar 06-23-2009 09:39 PM
straighten yer steering wheel and a tape measure. measure from outer tread groove to outer tread groove at the back of the tire. then measure from outer tread groove to outer tread groove in front of the tire.
if front is wider than rear, thread tie rods inwards. if rear wider than front, thread tie rod outwards
exitwound 06-24-2009 06:25 AM
A tape measure is hard to keep straight by yourself. If you have a partner, it's a good tool. We used a similar one to these:
http://wb6.itrademarket.com/pdimage/...augementah.jpg
It's a long bar that sits half way up the tires. First, striaghten the steering wheel. Measure the distance between the tires at the back of the tires. Then measure the same distance at the front of the wheel. Toe-in should give you a smaller distance at the front by 1° as stated above.
John_AZ 06-24-2009 07:21 AM
Here are a couple of links from easy to WT?
Basic instructions:
http://www.familycar.com/alignment.htm
I use this one from our TECH SECTION above^^^ when I changed my PS rack.
http://www.pelicanparts.com/techarticles/home_toe_in/home_toe_in.htm
Tire toe out calculator:
http://www.ground-control.com/toe-out.htm
OR
http://www.oz951.com/public/alignment.htm
OR
http://elantragtclub.tripod.com/elantra/id554.html
And a couple of others...
http://forums.rennlist.com/rennforums/924-931-944-951-968-forum/488296-anyone-do-their-own-wheel-alignments.html
OR
http://www.*****************.com/Digital_Camber_Caster_Gauge_and_Adapter_p/lr_78295.htm
OR
For my Jeep
http://www.go.jeep-xj.info/HowtoAlignment.htm
Another for my Jeep:
http://www.extremehowto.com/xh/printpage.asp?article_id=60130
Why? Maybe TexasBlake will add to his PS rack replacement DIY and put all this information together :D:D
GL
John_AZ
