Official Sponsor
vital-transform's Avatar
Cylinder Head Part #s 8R vs 7R
Just starting disassembly preparing to swap Cylinder heads and I noticed that my donor head ends in 303.7R
the head I am replacing is a 944.104.303.8R
my wishful thinking is that that means 1987 vs 1988?
is anyone aware of the difference in these two part #s?
it is a 1988 924S
1988 - 924S Guards red, auto trans
Old 06-24-2009, 10:23 PM
Greasy Member
many944s's Avatar
Nope, that number is just the mold number that the head was cast from, the date is usually found in the center of a round, slightly raised casting mark (alot of times not even present).
There are really only 4 different types of 8v heads out there:
1- the 951 head with ceramic ports
2- the very early '83 head with a 1/2" "surface area cooling hole" located between the #2 & #3 spark plug holes (only seen twice)
3- the '84 head with a turbulence notch in the intake ports to assist A/F mixing
4- the plain old run of the mill N/A head with no distinct features.
Hop it helps!
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 06-25-2009, 05:34 AM
WestonP22's Avatar
The later heads also have less valve shrouding.
#22 RaceRender.com Porsche 944
Old 06-25-2009, 07:51 AM
Official Sponsor
thanks, yeah they look pretty much the same just wanted to make sure
Old 06-26-2009, 07:42 AM
