Garage Helper
Cover over heater and AC blower motors
Hello all,
There is a thin plastic cover over the fan motor and other heat/AC system there. It is behind and above the firewall and goes back close to below the windshield. The question is how does one remove this cover to repair/replace the parts under it. It seems as if it is glued in place and quite thin and easy to tear up . Help. Thanks
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word |
All Spooled Up
I've never had mine off, but I think you need to remove the wipers.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
just took mine off to get to the expansion valve. it is held on by two strips of double stick tape, bend way up and push close to where its joined and it will pop off.
good luck |
Yeah, Right... (sarcasm on)
Good luck, George Beuselinck |
Clarks-garage.com might help. Haynes will have you chase your tail for two hours before you finally give up and use that overpriced thing for what is really good for. A WHEELCHOCK.
I think you have to pull the wipers and that rubber gasket on top of the firewall off to get that out. Oh George you were looking for green font there. |
Back from Beyond
Early car - two fasteners, one on each front corner (kinda - it's rounded at the front) and then cut the sealant with a sharp utility knife. Glue it back in when you're finished. Good time to replace the capacitor and oil the blower motor bearings, if they've got enough life left in them.
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
Garage Helper
Hello all,
I have a late 944 (1985.5), so the cover is stuck on with double sided tape? Take off the windshield wipers and proceed with caution - Thanks for all of the comments .
