Replacing the worn, stock shift lever.
I'm sure this has been covered before, but just in case.http://forums.pelicanparts.com/uploa...1248140598.jpg
1st,lift the leather boot http://forums.pelicanparts.com/uploa...1248140730.jpg 2nd, lift the rubber boot then remove the C clip from the shift knob and all comes right off. http://forums.pelicanparts.com/uploa...1248140853.jpg Exposed shifter. http://forums.pelicanparts.com/uploa...1248141007.jpg 3rd Remove C clip from shift pin and te shift tube sldes righht off. http://forums.pelicanparts.com/uploa...1248141113.jpg This is the lever we are replacing the stock one with, it is aluminum with adj. shift throw. Tools need are a Flat head Screw driver, 4mm Allen wrench & 13mm socket.http://forums.pelicanparts.com/uploa...1248141331.jpg 4th, Use the 13mm socket to remove the 2 bolds holding the shifter in place.http://forums.pelicanparts.com/uploa...1248141483.jpg This is what it looks like out.http://forums.pelicanparts.com/uploa...1248141630.jpg 5th, Push the base up the shift lever to pop the Plastic cup holding the base of the lever, now the lever will pop right out. http://forums.pelicanparts.com/uploa...1248141737.jpg 6th Pop the new lever in the cup just as you removed the old one. Bolt the base back in..http://forums.pelicanparts.com/uploa...1248141854.jpg |
7th Reconnect the shift to the new pin, replace the C clip.
http://forums.pelicanparts.com/uploa...1248142057.jpg This is what it should look like. http://forums.pelicanparts.com/uploa...1248142184.jpg 8th Replace the rubber boot, add the shift knob of your choice and you are done..http://forums.pelicanparts.com/uploa...1248142325.jpg Notice the end of the shift pin, that is the wear that causes sticky shifting. http://forums.pelicanparts.com/uploa...1248142465.jpg |
Hey the new Shifter look cool, and it is adjustable as well.
May I ask where did you get the shifter from. I want to replace mine, so I can use an after market shifter knob(Momo) |
Lindsey Racing make a short shift lever in the same style
Very nice write up. Where did you purchase your new shifter lever at?
I have seen them on EBay.
http://forums.pelicanparts.com/uploa...1248308021.jpg Maybe we can get Pelican to stock them? I use this method of rebuild: http://www.924board.org/viewtopic.php?t=18424 GL John_AZ |
i have a couple of extra perfect condition OEM shifters (not shift knobs) i'd be willing to unload super cheap - email me and i can even send you a pic if you'd like
| All times are GMT -8. The time now is 11:53 AM. |
