I really need your guys help! Any suggestions?
I need some more suggestions HELP
« on: Today at 9:36pm » Quote Modify Remove
Okay guys I've posted WTBs on 2 forums and no results. I've had 2 ALMOST hits but both were turbos and won't fit my 944 na. I have all of the parts I need to do by budget clutch job. Yes I know it's bad not to replace EVERYTHING and it's worse to use a used disk, but I don't have a choice right now.
I'm going to redo the clutch job again as soon as I get my bonus but I have to have a car un then. My pp and to bearing can handle a few thousand miles, I just need a disk.
I've had 2 offers for 60 bucks shipped for 2 almost new clutch disks pulled off of parts cars but both were turbo disks and wouldn't fit.
If anyone has any other suggestions BESIDES WTB ads on pelican parts and this forum or if you come across a decent disk PLEASE reply or PM me.
Thanks for the help guys
and if you plan on telling me how BAD of an idea it is to only replace this stuff and using used parts don't worry about it. I KNOW, but as I said before this is my only option right now and I am going to replace it fully in a few months!!
Thanks again,
matt
Old 10-07-2009, 07:38 PM
VII VII is offline
I would check ebay, post an ad on craigslist and call up local wreckers.
Old 10-07-2009, 07:54 PM
jerryw's Avatar
Try giving EASY Parts a call at
Tel: 510.653.3279
Fax: 510.653.3178
Email: info@easypor.com
They are good guys and may be able to get you the disk you need at a price you can live with. Tell them the 944Spec guys suggested you call
Jerry
Norcal 944Spec #552
Old 10-07-2009, 08:42 PM
Toofah King Bad
Rasta Monsta's Avatar
924Board.org :: View topic - Build a clutch disc for your 924S/944
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 10-07-2009, 10:41 PM
Custom User Title
Dave L's Avatar
try John at Welcome to A Part Above, Specializing in late model water cooled Porsche's
Old 10-08-2009, 05:49 AM
go get a mitsubishi starion disc for $30 at yer local autozone/pepboys. 90% chance of working. or get a clutchnet disc for 944na for $120
Old 10-08-2009, 06:06 AM
I think clutchnets up'd there prices to 145 plus shipping plus they want 45 bucks for 2 day shipping
Old 10-08-2009, 06:34 AM
Redline Racer
HondaDustR's Avatar
I have my old rubber centered disk with about half its life left. The rubber isn't cracked at all and it worked perfectly fine. I got a centerforce disk and am only replacing it 'cause I'm in there and it's rubber centered (thought all this time it was a new spring disk beforehand as the retarded PO claimed). If you are going to go right back in, it would do the trick and you can have it for shipping charges, probably ~$10 for priority mail.
I've got an extra flywheel too if you need one.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 10-08-2009, 07:29 PM
Damn impatience...I bought a used disk with 8 mm of friction material (new is 9.1mm or something) but I paid 90 shipped...oh well hopefully it'll last a few months until i get my bonus...
Old 10-08-2009, 07:45 PM
if it's 80% of new, it should last u much more than a few months. unless yer toasting yer clutch with improper driving.
Old 10-08-2009, 10:23 PM
Even if that's all I replace??
Old 10-09-2009, 04:10 AM
as long as the other parts are still in decent condition and not toasted, i don't see why not.
as long as the flywheel and pressure plate surfaces are still smooth, use some 600 or 800 grit sandpaper and just clean it up. there's nothing to really do with the finger springs on the pressure plate...but those are bad, then u gotta get a replacement. check throwout bearing that it still spins without hindrance.
it really just comes down to how desperate u are to not spend money now. u can get away with not spending anything IF everything is still in decent working order.
Old 10-09-2009, 06:02 AM
Proprietoristicly Refined
John_AZ's Avatar
If you get a good used OEM sachs disc, it should last at least a few years with 8mm thickness. (minimum is about 6.3mm). This photo shows a measurement of 6.7mm. 8mm is a good number.
GL
John_AZ
Old 10-11-2009, 06:26 AM
Phew. I thought i was supposed to have 8.3 on both sides! I was like ummmm I just got ripped off. Nope! I'm good! That so wierd though, because the disk i pulled out wasn't even close to the minimum, but the rubber did that. Could it be because the car wasn't driven much for the last 4 years and in the least few months it's been driven a lot?
The POs daily driver went out so he went from only driving this thing a few days of the month for 4 years to driving it every day. Maybe that with the fact that it sat uncovered for a while dried out the rubber and when he started driving it hard again the rubber started to go bad.
Old 10-11-2009, 07:26 AM
What a sheltered life I've had. This has left me speechless. I'm curious as how this idea came about. I want to throw the word ingenious at it! How in the world did someone make the connection between a Ford Bronco II and Porsche? Wow.
86 951 blk
Old 10-11-2009, 10:29 AM
Lol...a lot of trial and error or a redneck with good luck!
Old 10-11-2009, 02:18 PM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
Kudos!
Build your own Clutch Disk! Genius! Can I just make a few and sell em on Ebay or something? lets see....50 bucks to start, takes a few hours...hmmmm, even if not all that profitable you could really drive down a few prices.
That could save a bit. As last I recall...The throwout bearing is expensive as well. I can attest to the fact that MOST of the time you can re used the pressure plate with a little surfacing as long as the fingers are still good. There are a few "gotchas that will still cost some bucks (RM seal, fork shaft bearings, fork shaft?, FW bolts, etc.)
The labor is still a factor and not much to be done about that. Glad to hear that someone has made a little headway on this problem!
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 10-12-2009, 08:57 PM
Toofah King Bad
Disc diameter, shaft diameter and spline count.
Old 10-12-2009, 09:23 PM
