Transmission Oil Cooler Bypass/Rerouting/Replacing When Installing Rear Coilovers
Installing the Koni 30 Series Race Rear Coil-Over Kit on a 951 and surprise-surprise the right rear passenger-side coilover interferes with the transmission oil cooler line (coil). Is there a quick solution for bypassing/rerouting/replacing the transmission oil cooler line?
bump, I will have this problem over the winter I assume
Can you use some kind of fitting (like an "L" fitting) to route the oil line out of the way?
The way I see it, you will need to fab two fittings that matches the transmission oil cooler ends with standard 1/4" female NPT threads to adapt regular brass flare fittings to be able to install a 3/8" by-pass copper tubing.
If your not already, use a 2.25'' diameter spring in the back. Its still a tight fit, but the cooler loop can be tweaked slightly by hand to clear.
| All times are GMT -8. The time now is 10:39 AM. |
