Strange Gauge Problem
I have a weird gauge problem. Even before the car is started in key pos 2 the temp gauge pegs to full hot, it will stay that way until the car is running for like 15-20 minutes, i hit a hard bump in the road or if I tap on the glass hard. What could it be ????????
bad gauge
pull the cluster apart and clean the contacts on the back side. the little football looking things. the center is power and the 2 outside ones are the grounds. I used 1500 sandpaper and it worked just fine. worth a shot before you condemn your gauge
In the Pelican tech center ^^^^above on top of page, There is a good DIY on late guage fix.
http://www.pelicanparts.com/techarticles/944_taillight/944_gauge_problems.htm GL John_AZ 1988 924S + 1987 924S |
| All times are GMT -8. The time now is 01:02 AM. |
