Registered Speed Offender
Crazy Horse's Avatar
What is this part?
Hey group,
I have been taking apart the front of the engine to replace belts and water pump. I ran across this part, which had been disconnected by the PO and the two wires were laying beside it. It is located on the driver's side of the engine and is bolted to the airfilter box attachment plate on the back. I have a 1983 944 NA.
Any idea what it is?
Crazy Horse
______________
1989 930
Old 08-14-2009, 10:34 AM
Proprietoristicly Refined
John_AZ's Avatar
Is it connected to the AOS oil fill tube at the bottom?
Creative vacuum plumbing.
Old 08-14-2009, 11:04 AM
Back from Beyond
Idle switch/control valve. Cuts in when A/C turned on. The bolt in the top is a nice touch. The valve mounts at the back of the airbox and the bolt holes in its top are for (ta da!) mounting it.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 08-14-2009, 12:09 PM
Any reason the PO disconnected it?
Any reason the PO disconnected it? Do you know what its purpose is?
Crazy Horse
______________
1989 930
Old 08-14-2009, 12:43 PM
Originally Posted by slam View Post
idle switch/control valve. Cuts in when a/c turned on. The bolt in the top is a nice touch. The valve mounts at the back of the airbox and the bolt holes in its top are for (ta da!) mounting it.
+1
Good luck, George Beuselinck
Old 08-14-2009, 02:00 PM
I know the bolt on top is to mount it as I am the one that just "unmounted" it.
Crazy Horse
______________
1989 930
Old 08-14-2009, 02:14 PM
Boosts the idle speed to avoid speed dropping when the AC compressor kicks in.
The PO probably disconnected it because he was a dreaded PO, after all.
Old 08-14-2009, 02:19 PM
