Low Price Tow loops for 944s
I have been a bit bored lately and when I saw the rear tow hook that was on B&B Track Car Rental B&B 1.
So while at the local Home Depot picting up a few things, I started thinking,
I wonder if there is anything here that would work as a good tow loop??
1st I looked for a big stainless U bolt, but they didn't have anything bigger than what already was on the car.... The I noticed the Trailer tie down loops, less than $10 each Now I had my replacement Loop, next was hardware, well, some 3/8X1 Stainless allen bolts were the largest that would fit through the mounting holes in the tie downs, after grabbing some washers & nuts (They didn't have nylocks, so I will be replacing ASAP, but these are OK for now with lock washers..
Only simple hand tools needed to install, I went ahead & bough a 1/8s tap & bit ($8) since mine are metric & I wanted to play today..
Tape measure,
Drill, punch, tap, 8mm allen wrench & 14mm deep socket are all the tools need to do this to do this job...
OK, here we go...
1) measure where you want to mount the loop, there are ribs behind the bumper, so make sure you drill around them..
2) Mark your hole & drill.
3) Tap that hole!!!!! The bumper it's self isn't strong enough to hold, so this is just to give you a bit threads with the large washers in the back, small one up front.
4) Screw the bolt in, with the loop plate mounted, mark the 2nd hole & repeat the process. Add your washers, lock washers, you may need to bend the back washers to fit under the rib in the back of the bumper.
5) Clean up the bumper, either paint or powder coat the loops RED and either tough up the bumper or place a decal behind the mounts...
The front mounds the same way, but you will need to remove the bumper to fit the washers & nuts... I'm going to powder coat the front loops.
Now you can sit back & enjoy a nice Arogant Bastard Ale knowing that you have a solid tow loop at each end for a bit over $20
Now, there is one more thing, you may want to put something behind the loops so they don't bounce & bang on your bumper, I using pieces of Astro Deck, a foan decal for surfboard(I just happen to have a few peices around, will update when installed..
Old 09-03-2009, 07:05 PM
nice looking...but how strong is it really. what size bolts are u using? they look like maybe M8's? would hate to see the bolt just snapping when being towed.
Old 09-03-2009, 08:52 PM
3/8, stainless, but the bumper is threaded as well. That was the biggest that would fit through. The real plan is not to use them, but you saw what I replaced
I plan on later putting a stronger grade bolt. They are larger than the ones holding the bumper shocks...
Old 09-03-2009, 09:00 PM
lol yea def an improvement from before.
Old 09-04-2009, 06:12 AM
Toofah King Bad
Rasta Monsta's Avatar
GAH! No stainless, too brittle!
If I were running safety (which I sometimes do), I would not hook up to that contraption. People have been killed when tow straps or loops let go.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 09-04-2009, 09:39 AM
WestonP22's Avatar
Our safety truck no longer pulls cars for that very reason. They had one let go on them while they had a guy riding on the back of their truck. Now they push cars instead, often messing up the rear bumper.
I use the SafeQuip soft "bump draft" style tow straps... They've gotten me out of the mud a number of times.
#22 RaceRender.com Porsche 944
Old 09-04-2009, 11:04 AM
Schumi's Avatar
Tapping into the aluminum rear bumper - not the best. I'd at least put a through bolt, washers, and nuts on the back of it.
You used a beefy bolt and thread, and would probably be 'ok'.. but I don't know if that would pass CCW regs.
M
Old 09-04-2009, 11:08 AM
Look at step 3
Sorry, I thought that it was pretty clear when I washers in the back & that a 14mm socket was needed...
Old 09-04-2009, 11:30 AM
I'm only looking at track use, not pulling other cars & being towed, I have a trailer for that I do plan on upgrading to at least grade 3 bolts..
Old 09-04-2009, 01:54 PM
jasonmx5's Avatar
Would a flat steel backing plate make sense so you are not pulling on the soft aluminum? Just a thought.
"Making things easy is hard work"
My current stable: 1991 Carrera 4 Cabriolet, 1992 Mazda Miata, 2004 Lexus RX 330, 1994 F150 4x4 Supercab
Also rans: 1977 Carrera 3.0 (traded for C4 Cab.), 1983 944 (project car - sold)
Old 09-04-2009, 03:13 PM
Schumi's Avatar
Look at step 3
My mistake. Those big fender washers should distribute the load enough to be rather strong.
I still think some CCW rules require tow hooks to be bolted or welded to a main structure on the car, i.e. steel frame rails. But it's been awhile since I've read up on that.
M
Old 09-05-2009, 02:56 AM
This car is mainly used for DEs, and to Green Students and an occational race.
I though about that & may still do it when I pull them back off to have powder coated.. The problem is there are ribs behind the bumper so the washers were used..
Old 09-05-2009, 08:15 AM
Toofah King Bad
I'm only looking at track use, not. . .being towed
Maybe you should paint them on.
Old 09-05-2009, 09:01 AM
Turbo_ZA's Avatar
Send a message via ICQ to Turbo_ZA
1988 952 - Gold (Almond Beige Metallic), 18" Work Equips
2000 Jeep Cherokee XJ (Yes a SUV! - some days I feel the need to be a roadhog)
Old 09-05-2009, 01:12 PM
I mean only to be used if I have to be pulled off the track, not towing other cats from place to place. I have seen much worse at PCA races....
Old 09-05-2009, 02:28 PM
WestonP22's Avatar
If you get stuck off the race track and have to be pulled out, that tow hook is going to see a lot more stress than if you were simply towing on pavement. If it's not good enough for street use, then it's definitely not for the race track. And on top of that, you'd likely have guys standing nearby when the towing starts... if something gives out, that tow hook is going to go flying and possibly hit someone.
Old 09-05-2009, 04:22 PM
Yeah, coming from the world of Jeeps and off-road towing, that things bad. Don't hook to that...
Old 09-05-2009, 07:37 PM
