Low Price Tow loops for 944s
I have been a bit bored lately and when I saw the rear tow hook that was on B&B Track Car Rental B&B 1. ![]() So while at the local Home Depot picting up a few things, I started thinking, Quote:
Now I had my replacement Loop, next was hardware, well, some 3/8X1 Stainless allen bolts were the largest that would fit through the mounting holes in the tie downs, after grabbing some washers & nuts (They didn't have nylocks, so I will be replacing ASAP, but these are OK for now with lock washers..Only simple hand tools needed to install, I went ahead & bough a 1/8s tap & bit ($8) since mine are metric & I wanted to play today.. Tape measure,Drill, punch, tap, 8mm allen wrench & 14mm deep socket are all the tools need to do this to do this job... OK, here we go... 1) measure where you want to mount the loop, there are ribs behind the bumper, so make sure you drill around them.. 2) Mark your hole & drill. 3) Tap that hole!!!!! The bumper it's self isn't strong enough to hold, so this is just to give you a bit threads with the large washers in the back, small one up front. ![]() 4) Screw the bolt in, with the loop plate mounted, mark the 2nd hole & repeat the process. Add your washers, lock washers, you may need to bend the back washers to fit under the rib in the back of the bumper. 5) Clean up the bumper, either paint or powder coat the loops RED and either tough up the bumper or place a decal behind the mounts... ![]() The front mounds the same way, but you will need to remove the bumper to fit the washers & nuts... I'm going to powder coat the front loops. ![]() Now you can sit back & enjoy a nice Arogant Bastard Ale knowing that you have a solid tow loop at each end for a bit over $20 ![]() Now, there is one more thing, you may want to put something behind the loops so they don't bounce & bang on your bumper, I using pieces of Astro Deck, a foan decal for surfboard(I just happen to have a few peices around, will update when installed..
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
nice looking...but how strong is it really. what size bolts are u using? they look like maybe M8's? would hate to see the bolt just snapping when being towed.
![]() I plan on later putting a stronger grade bolt. They are larger than the ones holding the bumper shocks...
lol yea def an improvement from before.
Toofah King Bad
GAH! No stainless, too brittle!
If I were running safety (which I sometimes do), I would not hook up to that contraption. People have been killed when tow straps or loops let go.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
![]() I use the SafeQuip soft "bump draft" style tow straps... They've gotten me out of the mud a number of times.
#22 RaceRender.com Porsche 944 |
Tapping into the aluminum rear bumper - not the best. I'd at least put a through bolt, washers, and nuts on the back of it.
You used a beefy bolt and thread, and would probably be 'ok'.. but I don't know if that would pass CCW regs.
M |
I do plan on upgrading to at least grade 3 bolts..
Would a flat steel backing plate make sense so you are not pulling on the soft aluminum? Just a thought.
"Making things easy is hard work" My current stable: 1991 Carrera 4 Cabriolet, 1992 Mazda Miata, 2004 Lexus RX 330, 1994 F150 4x4 Supercab Also rans: 1977 Carrera 3.0 (traded for C4 Cab.), 1983 944 (project car - sold) |
My mistake. Those big fender washers should distribute the load enough to be rather strong.
I still think some CCW rules require tow hooks to be bolted or welded to a main structure on the car, i.e. steel frame rails. But it's been awhile since I've read up on that.
M |
Toofah King Bad
Maybe you should paint them on.
1988 952 - Gold (Almond Beige Metallic), 18" Work Equips ![]() 2000 Jeep Cherokee XJ (Yes a SUV! - some days I feel the need to be a roadhog)
I mean only to be used if I have to be pulled off the track, not towing other cats from place to place. I have seen much worse at PCA races....
If you get stuck off the race track and have to be pulled out, that tow hook is going to see a lot more stress than if you were simply towing on pavement. If it's not good enough for street use, then it's definitely not for the race track. And on top of that, you'd likely have guys standing nearby when the towing starts... if something gives out, that tow hook is going to go flying and possibly hit someone.
Yeah, coming from the world of Jeeps and off-road towing, that things bad. Don't hook to that...
