jasonmx5's Avatar
Project 944 is alive!
Well the '83 944 I picked up a few weeks ago is running! It probably hadn't started in over a year, so it felt good to bring the old girl back to life. Changed out the speed and reference sensors, and set the gap by feel just to see if she would run. Turned it over a few times and she coughed to life! Stalled out a few times (I suspect bad gas ) but after holding the throttle for a while to get her warmed up she fell into a nice steady idle at just over 900 rpms. Warmed her up and the fan kicked on as it should and took the temp right back down. Next task is to go through and replace all the fluids and pop in a new clutch master and slave. It will be good to get her back on the road again!
"Making things easy is hard work"
My current stable: 1991 Carrera 4 Cabriolet, 1992 Mazda Miata, 2004 Lexus RX 330, 1994 F150 4x4 Supercab
Also rans: 1977 Carrera 3.0 (traded for C4 Cab.), 1983 944 (project car - sold)
Old 08-17-2009, 07:52 PM
Toofah King Bad
Rasta Monsta's Avatar
(sung to the tune of "Spam" by Monty Python)
Belts, belts, belts, belts, belts, belts, belts, wonderful belts! Fantastic beeeelts!
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 08-17-2009, 09:25 PM
Avatar's are to SMALL.
Send a message via Skype™ to cvriv.charles
Congrats! Another 944 on the road. Agreed as above. While yor in thre change your belts And your plugs. Oil filter. Air filter. Check your cap and rotor.
Anyone care to add?
1986 951 - Wrecked. Being used for engine swap and parts.
1987 944 - SCCA specification track/ street car. Awaiting 951 engine and parts.
Old 08-17-2009, 09:58 PM
jasonmx5's Avatar
Oh yes, belts are also on the agenda. No need to go through all that work to get her running only to have it bend/break some valves.
Old 08-18-2009, 06:24 AM
