Throttle response cam installation question
I'm to the part where you adjust the pedal so as not to stretch/ break the cable at full throttle.........How do you adjust the pedal again? (Use small words and simple ideas please.)
Old 08-21-2009, 03:31 PM
That Guy
Techno Duck's Avatar
Take up the slack in the throttle cable by adjusting it at the bracket that bolts to the intake manifold. There are two jam nuts to set the slack. Finally adjust the white plastic screw under the gas pedal so that the pedal bottoms out on it with the throttle wide open.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 08-21-2009, 03:32 PM
Proprietoristicly Refined
John_AZ's Avatar
In addition to what Techno Duck advises, you need slack on the cable by the throttle cam for the throttle switch to work.
GL
John_AZ
Old 08-21-2009, 05:00 PM
Redline Racer
HondaDustR's Avatar
do you hear the click every time, even when the throttle is closed slowly? Don't try to adjust it to the very edge, or you will get intermittent closed throttle switch action, which sucks. If it's close enough to the edge of clicking vs not clicking, the switch may click but not make good contact.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 08-21-2009, 06:23 PM
