-   -   low idle with A/C on? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/494251-low-idle-c.html)
rb101 08-25-2009 04:21 PM
My daughter complained about her car stalling when coming to a stop. I drove it that night and had no problems. The next day I did some work on it and I noticed that when the A/C is on, it the idle does drop to sub 500 RPM. I pulled the intake and sprayed in some carb cleaner in the ISV and tested it. It works fine. When the A/C is on the idle should come up? How much?
Thanks for any other suggestions.
Rick
Crazy Horse 08-25-2009 05:11 PM
Check the AC idle air solenoid
On my car, mounted to the back air cleaner box attachment plate, is an AC idle air solenoid. I know this because it was disconnected when I got the car from the PO. After asking questions on this board, I realized what is was, that it was disconnected and that I needed to reconnect the wires to it. Before, when I turned on the AC, the car would idle about 300-400 rpm lower when the compressor kicked in. Now there is almost no change when the compressor kicks in.
Does your car have this solenoid?
HondaDustR 08-25-2009 06:06 PM
I think that solenoid was only on the early 944's. I think the later ones sent a signal to the DME from the AC relay, or something to signal an idle compensation setting.
rb101 08-25-2009 06:15 PM
I disconnected the ISV and the idle goes up to about 1100. If I plug it back in the idle drops and it will stall.....
John_AZ 08-25-2009 06:19 PM
The ICV/ISV valve is not giving the DME a correct signal. You may have vacuum leaks in the in and out hoses or the valve is dirty.
There have been a couple recent posts on how to clean the ICV/ISV or go to www.texasblake.com and see his writeup.
The ISV/ICV replaced the early solenoid.
GL
John_AZ
