jonvo's Avatar
What Does the "S" Have That I don't Have?
I have a base model 1987 944, and I saw a 1987 944S online for pretty cheap (it has a bent valve). I was wondering if it would be worth buying for parts. I know it has a 16v motor and makes a little more power. How about the transaxle? Does it has LSD and/or shorter gears?? Does it have bigger brakes? If I wanted to rebuild that motor and put it in my 944, would it be plug and play?
Old 08-31-2009, 10:31 PM
That Guy
Techno Duck's Avatar
Slightly different gearing and the 16v engine.. That is pretty much it. Nothing worth taking off really.
For the engine swap you would need the entire wire harness for the engine including the ignition module which is unique to the S and S2.
Old 08-31-2009, 11:40 PM
Avatar's are to SMALL.
Send a message via Skype™ to cvriv.charles
Is the S car that much worse off than your car that you couldnt just rebuild rebuild the S engine and keep it in the orignal car? And assume the car has bent valves. plural. Very costly. Tensioner pad.
1986 951 - Wrecked. Being used for engine swap and parts.
1987 944 - SCCA specification track/ street car. Awaiting 951 engine and parts.
Old 09-01-2009, 04:06 AM
rickharrison's Avatar
188 hp.
Rick Harrison
1988 944S
17 inch Cup 2's, euro bumper conversion
Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake
MaxHP chipped
Old 09-01-2009, 07:04 AM
Endat's Avatar
I'm rebuilding the engine in my S car... so far, so expensive. gonna be around 200hp when finished
Old 09-01-2009, 07:06 AM
jonvo's Avatar
It actually doesn't look too bad, but i have an attachment to my car. haha. I was thinking about pulling out the motor and slowly rebuilding it on the side as money came in. My 944 is my daily driver, so it would be nice to build a motor at my own pace without a rush to finish.
If i wanted to put this 16 valve motor in my car, or even the 3 liter S2, would the engine harness plug right into my chassis harness? (assuming it is from the same year) and are the DME plugs the same?
Old 09-01-2009, 07:29 AM
mistertate's Avatar
No, wiring harness is not the same, there's an extra harness for the ignition igniter on the S. Depending on the mileage on that S you might be able to fix it on the cheap. Last I checked valves were only about $25 each from EBS. It's probably not more than 8 you'd have to replace, then buy a headgasket kit
dude
Old 09-01-2009, 05:55 PM
Redline Racer
HondaDustR's Avatar
Yeah, shouldn't be too major of an operation to fix the motor, unless the chain tensioner in the head went bad, since it often gets torn off it's mounts, sometimes taking a chunk of the head with it, and eats chain gear teeth off the cams, which aren't cheap and hard to find, even used.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 09-02-2009, 12:49 PM
racer's Avatar
"S" has the same brakes as an 8V. Different final drive ration than the 8V.
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 09-04-2009, 03:05 PM
pontifex4's Avatar
The S also has the Turbo's brake bias valve.
I have also heard that something is stronger in the transmission (the pinion, maybe?)
And the S has some kind of auxiliary resonator in the exhaust which makes its exhaust somehow fit differently, if you're looking at swapping parts.
Charlie
'99 996 C2 6 speed - Arctic Silver
Old 09-04-2009, 08:06 PM
