Turbo_ZA's Avatar
Send a message via ICQ to Turbo_ZA
Lightbulb Bosch Oxygen Sensors New Part Numbers
This is from Bosch's 2009 Oxygen Sensor Catalogue. It quotes OEM part number in one column with the appropriate universal unit next to it.
The part numbers have changed - no idea how long it will take for the new numbers to filter down to auto part store levels.
ftp://arakis.gotdns.com/Downloads/Bosch%20Oxgen%20Sensor%20Porsche%20OEM%20&%20Universal.pdf
1988 952 - Gold (Almond Beige Metallic), 18" Work Equips
2000 Jeep Cherokee XJ (Yes a SUV! - some days I feel the need to be a roadhog)
Old 09-14-2009, 03:04 AM
Last time I replaced my O2 sensor, in July 2008, I purchased a Bosch #13942 oxygen sensor from NAPA for $43.99 + tax, and spliced the wires into my 968's connector, using solder and heat-shrink tubing. I kept the wires exactly the same length as the OEM so as to avoid significant changes to the overall electrical resistance.
The O2 sensor #13942 is for a 1987-1988 Ford Mustang V8. The sensor itself is identical to the Bosch #13011 that NAPA sells for $139.00 + tax; this speaks volumes about what we pay for Porsche's proprietary connectors!
Old 10-22-2009, 09:45 AM
Proprietoristicly Refined
John_AZ's Avatar
You must be fortunate to have the O2 sensor working after you used solder and heat-shrink tubing. I have never seen anyone advising using solder.
O2 sensors are to be crimped only.
From FR Wilk== http://www.the944.com/
Do Not Solder Wires!
Use wire crimps or Posi-LockÒ. All the latest BOSCH O2 sensors are air tight. But the O2 sensor must have a clean air supply to work. It breaths down the center of the multi-stranded wire(s). Solder and solder flux will close the air-gaps between the strands of wire and the O2 sensor may malfunction.
From NGK:
Tech info - Oxygen Sensors Overview
John_AZ
Old 10-22-2009, 12:13 PM
"You must be fortunate to have the O2 sensor working after you used solder and heat-shrink tubing. I have never seen anyone advising using solder."
Well, I did, and would advise anyone to do the same. It's a secure connection in a high-temp environment. Electric current didn't seem to mind.
Old 11-14-2009, 04:27 PM
thekidd's Avatar
Send a message via AIM to thekidd
People have said that a Ford Taurus oxygen sensor works in our cars, but dont know the model. I think 924board has a page where they have alternative part #'s for our cars.
Steve- If you havent looked, look- www.clarks-garage.com
87 951 red- Maria (current)
84 944 white- Percilla (current DD)
85.5 944 red- Pinta (past)
87 924S red- Nina (past)
Old 11-15-2009, 08:54 AM
John_AZ's Avatar
Link from fr wilk:
Oxygen Sensor
John_AZ
Old 11-15-2009, 09:01 AM
