Send a message via AIM to ScoobySteve
I hate this $&@"%#^ car
My OPRV sheared off while trying to remove it. I have the head, some of te threads, and the spring.
So two weeks ago I had a car that ran with a little coolant smell in the exhaust. Now I'm $2200 poorer and have a car that doesn't run at all.
Old 09-25-2009, 05:20 PM
Proprietoristicly Refined
John_AZ's Avatar
Steve,
Sorry to hear about the frustration.
Your 1986 944 should have the "one piece" valve.
Can you add a picture of the parts that came out?
The "one piece" valve does separate to get to the intermal "O" ring to replace
The bottom half may be stuck in the hole. In any case, you need to remove the oil cooler housing if you cannot get to the stuck piece. Here are the instructions to replace the 2 "O" rings and it may help visualize the piece inside the block.
GL
John_AZ
Old 09-25-2009, 05:36 PM
I'm on the iPhone but it looks like mine sheared at the threads in part #1 as mine is much shorter than the picture depicts.
Steve,
GL
John_AZ
Old 09-25-2009, 05:46 PM
John_AZ's Avatar
This is what the early "3 Piece" oprv looks like (by djolin)
Does your spring look like this one?
GL
John_AZ
Old 09-25-2009, 06:17 PM
Nope. It's a one piece. I just got it out of the housing. It sheared in the middle of the threads. More alarming is the housing. There are spots where the threads are broken off. Not crossthreaded, not galled, but snapped off. I've got photos I'll upload later.
Old 09-25-2009, 06:26 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
You should be able to find a used OPRV assembly for about a hundred bucks. Why are you in the hole $2200? That seems simply astonishing for this particular job. It's not all that hard.
Black Cars Matter
Old 09-25-2009, 06:46 PM
Well, this is part of major top-end service:
- Head gasket (and new freshened head)
- Front of engine seals
- Miscellaneous WYAIT under intake manifold items
- Belt and water pump service
Below is are some photos:
-Stephen
00 Boxster S 6MT
03 Subaru WRX w/EJ207 swap
16 Cayman GT4
21 Genesis G70 3.3T
Old 09-25-2009, 09:04 PM
Wow, the housing is f***ed. Not sure if you can get a thread chaser that big.
Evidently, the housing is not lined up with the block when your mechanic probably forced the OPRV with a ratchet and socket. It should thread in easily by hand and tightened with a wrench later. The OPRV threaded section is thin walled and can break where the o-ring sits on a groove inside the threaded piece and the bore is tapered to allow it to go in easy but not easy to pull out.
You may need a new oil cooler housing and OPRV. Call Georgeb, he may have one set on the shelf.
You are already out by $2200 so another maybe $200 will be change.
Good luck!
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 09-26-2009, 05:19 AM
Heli coil insert if you can Drill and find right size. Probably on line since it's metric! A woodbee machineist kid would probably do for 50-70$ if you get the right size drill bit and Heli coil. Try to find a local kid that can come by after his normal machine/auto job and make some extra cash.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 09-26-2009, 05:27 AM
Redline Racer
HondaDustR's Avatar
check your PM's. Now that it's a more civilized hour and I'm thinking clearly again, it should be easy to find a new oil cooler housing if you would rather not mess with replacing the threads. The problem with replacing the threads is, since the OPRV depends on such an exact fit, the threads will have to be exactly straight and centered. For some reason I was thinking the threads were in the block.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 09-26-2009, 09:42 AM
+1
Idiots and tools should never mix.
Still, getting a helicoil in that should be a relatively easy/simple matter - probably need to call a few places to find one that has the correct one for that size/thread pitch though.
Black Cars Matter
Old 09-26-2009, 10:36 AM
