Addicted to Racing
944 vs 951 head
What is the difference between the NA and the turbo heads.
Thanks Ed
Check out the parts for sale: http://www.demonspeedmotorsports.com PCA National & NASA Instructor, NASA GTS & PCA GT Class Racer. See my list of current cars in my garage. |
For one, the turbo head has ceramic liners in the exhaust ports and sodium filled valves, the N/A does not.
turbo has sodium filled exhaust valves, ceramic liners in exhaust ports as mentioned and better valve springs. believe the intake valves are larger also,
Dog-faced pony soldier
However (something to consider) because of the ceramic liners in the 951 heads, it is impossible to increase the size of the exhaust ports. Very highly built 951s often use the NA heads for this reason (flow becomes an issue).
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Redline Racer
The ceramic liners also have a tendancy to crack. Lindsey Racing does alot of work on turbo stuff and claims they can significantly increase the flow through the exhaust ports without doing anything to the ceramic liner, which would be better overall, since it keeps the exhaust hot and the head cooler.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
