What would it cost....
Can an open diff trans be converted to lsd and if so what would it cost? ballpark
Old 09-23-2009, 10:26 AM
flash968's Avatar
i added lsd to mine - was about $2k all in with a brand new unit
Old 09-23-2009, 10:33 AM
Redline Racer
HondaDustR's Avatar
It's not cheap, since you have to disassemble the final drive and re-shim the gears for clearance, plus all the WYIT stuff like bearings and maybe syncros. and maybe replacing the LSD clutch plates.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 09-23-2009, 11:44 AM
Used & Abused
about $450
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 09-23-2009, 04:04 PM
Is it do-able by a novice wrench? Would I need any special tools? AND would a 951 trans fit in an 85.1? Still using stock 8" Fuchs?
Old 09-23-2009, 08:38 PM
flash968's Avatar
"450" and "i don't know" seems to fit - no chance of getting it done for that
first, never install a used clutch type unit without replacing the friction material - even a used lsd is going to be a few hundred - then you add in the new parts
second, since the trans comes out to do this right, how do you get it out, apart, set up, and back together in less than 12 hours? that's a good grand right there
this is not a job for an amateur either - setting up a diff correctly takes precision tools and experience - thrust and pre-load are critical - do it wrong, and you get to start all over again and replace a lot more stuff that got messed up
i do most of my own wrenching, have done almost everything at one time or another, and don't fear ripping down an engine - i even had a shop years ago, but diffs are something i leave to professionals - i've seen the ugly results of just slapping it together
the R&R isn't a big deal though
Old 09-24-2009, 07:43 AM
Misunderstood User
Honda is correct. It can be done but mods are required for the trans. Not sure on the cost but you would need a lsd unit.
Other options: Check with Ian at 944online of George at 944ecology for a complete trans w/lsd unit.
Flash is correct about $2K for a new rebuilt.
A 951 tranny has different ratios than a 944 n/a tranny. It is not the way to go.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 09-24-2009, 07:46 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
I think a Quaife can be had for around $1,500. Beyond that, throw in a few hundred bucks for the incidentals (as is mentioned above) and you're right around $2k. If you plan on having someone else do it for you, double the cost.
Black Cars Matter
Old 09-24-2009, 07:49 AM
