Clutch pedal at half-way up
1989 944S2
Suddenly my clutch pedal does not come all the way up. The clutch still works - but there is only 1/2 of the normal "movement." I can pull it all the way up with my foot. When I press down - the pedal springs down half way - and then starts to work the clutch. What can be wrong? I had a clutch job about 3,000 miles ago. Dick |
Feelin' Solexy
Your master and slave cylinders are failing. Fortunately, this is a fairly easy job that can be done with basic tools and 2-3 hours of time.
See here for a good how-to: Clutch Master Cylinder Replacement Clutch Slave Cylinder Replacement
Grant In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S |
Custom User Title
yup, master and slave. Although only one might be leaking its best to change both.
Push the pedal all they way down quickly while shifting and see if that temporarily relieves the problem. If so, it's most likely the seals on the master or slave going bad. If not, you may have the same problem I'm struggling to figure out where the pedal gets soft under hard braking and sticks half way back up. I replace the system on mine but it didn't get rid of the problem.
Id bet mnoney its your firewall. Mine gave way in exactly the same manner as yours, whats happening is the thin firewall has cracked or broken and is now flexing outwards, its a pain to fix, ive seen people make braces from the strut tower to the firewall to hold it in place, but i just made up a plate of alum that i bolted over the damaged section of the wall and then mounted the master to.
check your clutch inspection hole, if you have fluid coming out of there it is a pre sign of master/slave cylinder failure, my clutch pedal did not return to its full position before my cylinder died.
*1988 944 NA with front end Turbo Conversion* *1968 400 cubic inch bored and stroked Firebird* |
All Spooled Up
Wouldn't trapped air also cause this symptom? Has the system been bled?
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
