christojen's Avatar
It is a question of size (911 v 944)
Hello chaps!
I am actually a 911 man but am thinking of upgrading to a 944 for various reasons mostly to do with practicality and cost....
I would like to know if the 944s are bigger / smaller in any dimension that a 77 911? The reason for this is i need to know if i will be able to fit it in my garage. So i guess i also need to know about the turning circle.... (it is a tight lane and 90 degree turn into a narrow garage) I can get the 911 in in about 2 turns.
Thanks all. I am in australia (the everything is reversed)
Chris
Old 10-29-2009, 01:39 AM
ERAU944's Avatar
Send a message via AIM to ERAU944
i wish i had more helpful info, but i got stuck reading the part where you're
"upgrading from a 911 to a 944"
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 10-29-2009, 04:35 AM
944 is wider, I have both and the 944 is only marginally tighter where I turn out of my garage, but there is a difference. Much more space in the car, especially with the hatch. Much better as an everyday car.
Art
'75 911 US Carrera #390
'74 MGB, AH 3000 BN7 V8,
'65 Mustang Fastback, 66 bronco U13
Old 10-29-2009, 04:40 AM
944 is a little under 14 feet long. turning circle imo is pretty tight, i can do u-turns sometimes into the first lane
Old 10-29-2009, 10:07 AM
Endat's Avatar
Sounds like an upgrade from a 911 (930?) Would be a good option for you. I think maybe the 911 has more engine and power though.
Old 10-29-2009, 10:31 AM
Length 4200mm (165.3 in) width 1735mm (68.3in) height 1275mm (50.2 in)
Turning circle 10.75 meters (35.3 ft)
From "Ultimate Buyers Guide"
88 944 na
07 335i
12 Cayman
Old 10-29-2009, 07:18 PM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
The length you quoted is for the "European" 944; the US bumpered car is longer.
Unfortunately I know these things without looking them up for many of the 9000 different types of car I've made car covers for( wish I knew how to make pots of money instead!!!)..
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 10-30-2009, 01:32 AM
My friends call me, Top
Skytrooper's Avatar
944 is wider. I just looked in my garage. They appear to be about the same length (with US bumpers)
Matt
'87 924S
Old 10-30-2009, 03:22 AM
Yep, the 944 is about 2" wider than the 924S, but same length
Old 10-30-2009, 05:53 AM
RichardE's Avatar
If you are changing to a 944 get an S2 manual. Ideally, get the 944 and hide the 911 in a mates garage. The 911 will start holding it's value better than the 944 too.
89' 930 LE stock standard
90' 944 S2 also original
75' 914 2.0
Old 10-30-2009, 06:56 PM
TibetanT's Avatar
You know this is a subject for debate, but the 911 is much cheaper to maintain than the 944.
Of course, it all depends on what parts you use, who you buy your parts from, and whether or not you use Synthetic oil all the time.
Like I said, "a subject for debate" but my 911SC is much cheaper to maintain than the 944.
Just my .02 cents from experience.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 10-30-2009, 09:21 PM
