Running Fuchs on an 87 944
I posted this same thing on rennlist and I also want to get the Pelican guys thoughts.
Im pondering the idea of trying to run Fuch wheels on an 87 with a late offset. Has anyone here tried this ?? I know this has come up ( with the answer being no) but a few people have said you can if you use a narrow wheel. Take a look at these pictures I found of a 1989 944 with fuchs they appear to be sticking out a bit in the rear but Im thinking the if I go down a size they should tuck in there. Thoughts ?? http://autolivery.com/assets/cars/KN450888-16sm.jpg http://autolivery.com/assets/cars/KN450888-10sm.jpg |
Looks like that car in the pictures is running a 6 inch wide in front, and a 7 inch wide in rear. If you go down a size, you will be running 6 inch wide wheels all around?? Looks like it might work, but it might look kind of funny! :(
I have an early 944 with the offset you need! I want to run later wheels on my car, but I don't really want to use spacers. I wish I could trade you offsets! LOL! |
Theres a fellow on rennlist who ran 7x15s with lots of negative camber.. and it worked. How stock is your suspension? What size tire do you want to run.
While it *could* work, the question becomes.. why? to be different? One advantage to the late offset cars (87+) is the huge number of factory and aftermarket wheels available to use. |
Why - I really like the look of the fuchs wheel.
Suspension is stock with exception of Koni shocks and struts. |
Would running alot of negative camber hurt anything ?
How serious are you about doing this? Swapping the necessary suspension components to "convert" your car to early offset could be done in a weekend.
And I am with you, I LOVE those wheels. Maybe it's all those Hot Wheels cars from my childhood. . . |
What is all necessary to change ? If it involves shocks and struts im not b/c I just got Konis installed.
| All times are GMT -8. The time now is 09:02 PM. |
