968 Cruise Control
I use my car primarily at the track - but I drive it too and from. Typically, to avoid driving on the interstate the way I do on track, I use the cruise to get me home.
While driving home one day the cruise did not work. The next day it was back (hooray) but then it has been gone ever since. Is this a bad relay? Switch? any other ideas?
I have looked at the brake and clutch switches and they seem to be fine.
All help is appreciated.
TomR
Old 11-03-2009, 10:48 AM
In the Fires of Hell.....
kdjones2000's Avatar
Typical symptoms of the CC brain starting to go. Check out Clark's Garage on resoldering the connections, or try another used one from Fleabay or here.
Good luck, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 11-03-2009, 12:30 PM
flash968's Avatar
check your brake light bulbs and their connections
Old 11-03-2009, 12:51 PM
FRporsche's Avatar
I think it's just starting to go. Be careful, when this happened to my 944 and it finally failed, it got stuck in full-accelerate mode!
'87 951 | '87 951 | '87 944 | '93 968 | '84 944 | '82 911
'82 300TD | '77 6.9
Old 11-05-2009, 11:19 PM
