Mark944na86's Avatar
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
Leak around brake master cylinder
Here's a brake fluid leak showing up around the base of the brake master cylinder where it join the brake booster drum:
What's the diagnosis? Is this where you would expect to see fluid leaking if the master cylinder seals had failed? Or would this be something else?
Currently 1990 944 S2, Black on Linen, 17" Turbo Twists
Old 11-25-2009, 02:23 AM
Sounds like your brake master is starting to fail. Look inside the car up inside where the brake master rod comes through and you will probably see a trickle of fluid coming down the fire wall as well.
Old 11-25-2009, 04:09 AM
Leaking grommet?
Upon closer inspection, the source of the leak seems to be this grommet where the brake fluid reservoir connects to the master cylinder:
Is this a common source of leaks?
Old 11-25-2009, 04:17 AM
I believe you should repalce your brake master cylinder. They will leak from the back when going bad.
Old 11-25-2009, 04:23 AM
Toofah King Bad
Rasta Monsta's Avatar
. . .and as zed said, check inside around the brake pedal. If there is brake fluid on your floorboard, scrub it out ASAP (and replace master).
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 11-25-2009, 07:47 AM
ernie9944's Avatar
Check under the MC reservoir the grommetts migth be gone,happen to me had the same problem ( easy fix).
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 11-25-2009, 07:55 AM
Ernie nails it -- one split grommet. And yes, was an easy fix. Thanks guys.
Old 12-01-2009, 05:20 AM
