-   -   DE rules ect... (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/510104-de-rules-ect.html)
fast924S 11-10-2009 03:29 PM
DE rules ect...
Does ANyone know what the rules are for race seats?? I know if the Driver has 6 point harness then the Pass needs it too, But I have one used race seat, Can I use one race seat and one factory seat and just put 6 points on both???
Skytrooper 11-10-2009 03:35 PM
I believe that you must provide the instructor the same seat and harness that you are using. Putting a 6 point on a factory seat would not provide any real safety for the instructor.
krystar 11-10-2009 03:53 PM
yea the whole SYSTEM has to be equal safety. harness, seat, rollover protection.
you'll definitely need a 6point capable seat on the pass side. and at least a rollbar.
check with your local org to see if they allow different brand/model seats. but both seats have to have subbelt holes from the factory and both harnesses have to be mounted safely, esp the subbelt harness.
read up on mounting subbelt harness cause I just went thru this whole ordeal too. john hajny aka the redline guy has some pretty convincing statements about past and current rules of safety equipment. i read the threads on rennlist but they might be here on pelican also
fast924S 11-10-2009 03:58 PM
Yea Guess I'L have to look into it. I got the track bug LOL. Right now I gotta upgrade seats and suspension. Im running factory seats, and man do you slide all around those things when hitting hard corners. I figure seats and cage first, Then worry about suspension.
flash968 11-10-2009 04:31 PM
DE events regulations vary WIDELY from organizer to organizer - it is generally VERY different than racing regulations
i have never heard any requirement regarding matching left to right seats or belts - in fact, no organization out here requires that
what if you had no passenger seat at all? how would that match?
they do require that if you have a standard seat, that you cannot run harnesses in a porsche, because the harness must pass through the seat at the headrest, and our seats make no provision for that because it would not be safe
roll bars are not required in any hardtop car in any DE i have ever heard of, and not even in a cabriolet in a number of events i know of, though that is disappearing
that does not in any way mean that i don't think that all of those things are good ideas - be safe
kdjones2000 11-10-2009 04:38 PM
For PCA and NASA DE's, the stock seats/seatbelts are fine. No roll bar is required, unless you are driving a cab without a built in roll bar. (The 944 cab would need one, for example).
Racing, Time Trials etc. are a completely different story when it comes to equipment. And like Flash said, more is better when it comes to safety.
Cheers, Keith
fast924S 11-10-2009 04:39 PM
Its for DE and auto cross use only. But the PCA CVR here rules that both pass and drive must have matching seat belts. In DE when you start you drive with a instructor, guess they want the same safety?? Im still not sure about seats yet LOL. Ohh kinda Off topic, ANyone Got a Bolt in Roll Bar/cage for sale that will fit a 924S????
Techno Duck 11-10-2009 05:19 PM
Talk to John Hajny, if i remember right hes in Vestal, NY. He makes a 4pt bolt in roll bar (its more of a extremely heavy duty harness bar) that is probably one of the best options and requires no modifications to the interior if that matters to you. They also hold there value very well, so when or if you want to move up to a weld or bolt in half cage you can recoup a good portion of your purchase price.
The rules for all of PCA are equal restraints. That does not mean everything has to be the same, but if you have a harness on one side, you need it on the other...everything being the same brand does not matter. Seats are the same deal, you can do say a fixed back on your side and a recliner (with proper shoulder belt holes) on the passenger side. This is not a bad idea because there are some plus size instructors out there.
BTW, here is his webpage. http://www.redlinerennsport.com/SafeguardPage.html
He goes by RedlineMan on RL.
krystar 11-10-2009 06:09 PM
for DE's, the issue is that you're going to have an instructor. if you were already going solo in experienced group, then you're right, I don't see the purpose of having a pass seat at all.
but seeing as you're going to have to start in novice, you're going to have to have an instructor. the way i see it, your options are as follows:
1) stock 3pt belt on both sides
2) 5/6pt belt + race seat on both sides properly installed and a rollbar/rollcage
i was allowed to DE once with schrothe rallye 4 DOT 4pt harnesses on race seats for both driver and pass. but PCA said that it would only happen once and I was fine with that. Right now I already got 6pt's in both and rollbar is in the mail.
as for autocrosses, most of the time you're going solo anyway. i've had no problems passing tech and feeling safe with schrothe rallye4 harnesses on a race bucket seat.
Rasta Monsta 11-10-2009 06:31 PM
PCA National.
flash968 11-10-2009 10:14 PM
i'd have to see that one in print - i've done pca DE events out here and there was no such requirement, or even mention of it - it doesn't even make sense to have such a rule - this could easily make the car less safe by means of having to opt for stock seats and belts just on the off chance you wanted an instructor in the car on occasion - a race seat and harnesses are better at limiting driver movement, thereby making the passenger safer - if that rule exists, it's just plain shortsighted and stupid
of course, i probably wouldn't do another pca event anyway - they are so litigation freaked that they are doing some very odd things these days - it really has nothing to do with safety with them - it's all about not getting sued
POC is MUCH better - so are most other organizers
Rasta Monsta 11-10-2009 10:19 PM
:eye roll deluxe:
http://www.pca.org/portals/forms/PCADE_MinimumStandards2009.pdf
I may have to disagree with your assessment of our program and it's rules. Your comments about the equal restraints are spoken like someone who has never worked as a DE instructor.
:eye roll sprain:
Aslet 11-10-2009 10:39 PM
Autocross there are no requirements, it would be the call of an instructor.
DE: As said you need the same belt system and the same type of seat (mainly they don't won't you running a 6pt belt with stock pass seat since that doesn't work). The seats and belts have to be "equal". This doesn't mean that the belts and seats are the same. Many drivers run different seats for the pass side. As long as the seat works with the belts you shouldn't have any issues with tech. Again it comes down to the instructor though. If you have a race seat for the driver and the pass side is a reclining seat (even with proper holes) an instructor always could say they aren't comfortable with the system (I've never heard of this happening though).
Have you done any CVR autocrosses? I haven't seen you around. Hope you do some next year!
flash968 11-11-2009 07:43 AM
rasta - i get the desire to be strapped in - i am NOT suggesting that all cars on the track should not have race seats and harnesses in both sides
however, in a DE, the idea is to train the driver - the driver can be more easily trained if he is not having to worry about moving around in the seat - the driver is also more likely to be able to control the car if he is strapped in - forcing someone to DOWNGRADE their safety gear for the comfort of the instructor is counter-productive to both goals
choosing the lowest common denominator in safety gear is a very bad idea
this is a dumb rule
so is requiring the soft top to be in the UP position - this is extremely dangerous in the event of a rollover - those metal bows are well known for causing injury and death from impalement, far more than any chance of arms flailing about or debris entering the cabin
what if you don't have a top at all? the race car about to be built won't even have a windshield, let alone a top
krystar 11-11-2009 07:59 AM
yes the driver would like to be strapped in. but as the driver of the car, you are also responsible for the passenger/instructor that's going to be in the car. it is not about the comfort of the instructor but rather the instructor's safety as well!
if you were the instructor and your student driver has 6point harness, race bucket, roll bar on the driver side, but only a lap belt and a stock seat with no rollover protection on the passenger side, would YOU get in?
flash968 11-11-2009 08:19 AM
yes - no problem
i would feel safer if i knew that the novice driver was safely in place and not squirming around, even if it meant that i was - it is more important that the driver, who is in control of the car, not me, to be locked in place than any mental perception of safety
again, i am NOT suggesting that both seats should not be proper race seats and that both should have harnesses
i am only saying that if it means that the driver has to stick with the crappy control the stock seats provide, then BOTH are at a higher risk than if the driver were secure
this rule is purely a litigation based one - it arose because some instructor got hurt and wanted to sue PCA
PCA is paranoid about litigation - they are now prohibiting driving events (fun runs and such) in some zones - that's just plain nuts
this is just one of the things that bugs me about PCA - they have completely forgotten what these cars are about
another thing that really cracks me up is their waiver - it won't stand up in court anyway, so why bother? (yes, i've spoken to attorneys about it) waivers in general aren't worth the paper on which they are written, but you cannot have a waiver with multiple parties on it
petrolhead611 11-11-2009 08:24 AM
Idon't know if they sell CG Lock in the US, but I use one for AutoX with leather seats( yes, I should never have ordered them, but originally the car was a present for the wife), and we have very tight turns on our AutoX because the rules dictate that we have to have a tortous route.. The CG locks allows one to pre-tighten regular 3 point safety belts, and stops one sliding abvout.Ain't no substitute for a proper harness and race seat if you are going to have a high speed crash though.
krystar 11-11-2009 09:09 AM
yea flash, i can def imagine it being a liability issue. and yes waivers don't mean squat. it is def perception of safety. but if the driver of the car can "more safe" than the passenger, then what incentive does the owner of the car to provide any safety equipment at all for the passenger? just playing devils advocate here
flash968 11-11-2009 09:16 AM
i know - but, it makes more sense to improve the driver as much as we can, and limiting him to stock safety equipment because of a rule like this inhibits that progress
most guys don't want a race seat in the car every day, and certainly don't want to have to remove both for each DE, especially if they aren't going to use an instructor - most guys take their daily driver to a DE - most guys with 944s can't afford 2 seats and harnesses, at least not right away
so, we choose to exclude them from learning how to drive better? how does that make things better or safer?
the logic of opting for the lowest common denominator escapes me
if they want harnesses and race seats in the cars, then they should just require them - this odd "gotta be the same" rule is just silly
but then, PCA is the club of exclusion, so this only follows their pattern and is to be expected - they are all about finding ways to turn people away, rather than welcome new members and friends
i wouldn't maintain my membership, but they won't let you into parade unless you are a member
Techno Duck 11-11-2009 11:10 AM
PCA is not the only club that does this; BMW CCA and a few others in my region are the same way and have been like this the past 2 years (maybe more than that. If you are willing to increase the safety margin on your side, you should allow the instructor the same luxury. There is no reason to do a fixed back 'race' seats as you can simply go with a recliner with the proper shoulder slots. If you wanted to get a nice flexible Scroth harness on your side and a cheaper, not as flexible and uncomfortable G-Force harness on the passenger that is not a problem. The rule is equal in function, not color.
Yes, they are probably turning some people away who dont want to spend money on the equipment, but i think most people get this isnt exactly a cheap hobby. There is no rule against not running harnesses, but i think most drivers see the benefit of them after a few events after they feel like there about to deform the metal that makes up the dead pedal.
944Spec_bound 11-11-2009 12:11 PM
To paraphrase Quentin Tarantino, "This car is Deathproof, but you really need to be sitting in the driver seat."
Match the passenger to safety of the driver, it's the right thing to do. A word of advise though...when you register let them know you have a cage and or racing seat and the WIDTH of that seat. I had a rather husky instructor assigned once, he squeezed in but I thought they'd need to call rescue crew to extract him from my 17" seat.
krystar 11-11-2009 12:24 PM
yea but i bet he was real secure in the seat hehe. prob didn't even need the seat belts.
flash968 11-11-2009 12:33 PM
again, i am not suggesting for a minute that it is not the best thing to do to install the good stuff on both sides
all i am saying is that this is NOT racing - this is DRIVER EDUCATION - the point is to teach the driver - far too many people use a DE as if it were a race event, and therein lies the problem
the rule is counter-productive to encouraging more people to learn to drive, which should be the primary goal - a stock seat is not as safe as a good one - stock belts are not as safe as harnesses - a driver flopping around in a stock seat and belts is more likely to lose control of the car at exactly the wrong moment, and injure both he and the instructor, than one who is belted in correctly
absolutely i'd like to see both seats done up right - but if that can't happen, i'd much rather see at least the driver seat right - at least that way i am less likely to get nailed by a squid
944Spec_bound 11-12-2009 02:46 PM
I don't know about PCA, but this is from the NASA CCR:
11.4.8 Seatbelts and Harnesses
The seatbelts should be in good condition. No damage may be present on the seatbelts
and they must be the factory configuration. Any harness or any restraint system, other
than factory stock, shall conform to CCR section #15.5, in all respects* except for the
expiration regulations. Harnesses that are expired for racing may be used providing that
they are in at least very good condition. The use of a lap belt without any shoulder
restraint is not permitted. Passenger seatbelts must meet the same minimum
requirements per the CCR as the driver seatbelts if being used by a passenger.
Note passenger
equipment need not match the installed equipment on the driver’s side.
*Aftermarket DOT-certified belt sets, installed to the manufacturer’s specifications may
be allowed. Proof of DOT certification and proper installation is the driver’s responsibility.
So if you have 5/6 pt harnesses for driver, that means you also have a racing seat and rollbar or cage to fasten harnesses to... therefore you need the same thing for the passenger side.
Equipment doesn't have to match...meaning, like my car, I have a road race seat and a rally seat but both have equal harnesses and anchoring.
racer 11-12-2009 03:24 PM
Agreed.. but with folks now coming to events in 200-500hp cars, the speeds that can be acheived are so much greater than with an 80hp 914. Given lesser experience and incredible cars, it could stand to reason that ensuring potentially better safety (i have seen no studies published) helps all involved.
Yes it is for teaching.. but how do you teach control (approaching and exceeding a cars performance limit) when the limits are so incredibly high, right off the factory floor?
I don't think the rule is the issue.. The issue is the "consumer" thinks that all the equipment is needed. Its not needed at all. But peer pressure and a little walter mitty feelings conjure up the need that, to learn better and go faster, I must modify my car.
Sometimes, its downright fun to slide around. I went from a full track prepped SC to a bone stock boxster and had a hoot. Sure I had to remember how to "brace" myself, but, well, it was fun.
As for the OP, yes, "equal restraints" is the key. If "you" want a race style seat, assume the instructor does too. You could just keep the stock stuff and not worry about the financial outlay. It is, after all, DE and not racing ;)
flash968 11-12-2009 03:49 PM
944 spec - i think you misread something - while the harnesses for the driver would certainly be attached to the roll bar, there is no requirement that the passenger seat have harnesses or be attached to the roll bar
racer - i understand what you are saying, and don't disagree for a second with the wisdom of choosing to have the gear - i've got it on both sides in my car - all i am saying is that it deters a lot of people from attending that would otherwise become better drivers
as for the fast cars being out there causing problems, this is an organizer problem - they need to break up the run groups so that you don't have a GT2 out there with a miata just as much as you need to break them up so that novices aren't out there with experienced drivers
Aslet 11-12-2009 05:47 PM
FIRST, where are you running that a MIATA is on the track with you! Out events in CT are Porsche only, which is nice by keeping the cars fairly even. Not to mention that in low run groups a 944 can pass that GT2.
Overall for safety: Make the driver and pass side the same setup. You will never have issues that way. As far as needing safety gear, what comes in the car stock is fine to learn in. The issue starts when you get into higher run groups and get more g-force when driving (since you get better and faster). The stock seats and belts can only hold you so well. I am changing to race seats and harnesses this winter to help hold me in. I am a large guy and don't have much room in a 944 to move, but I do when on track. When you get to the point you are bending the steering wheel just trying to hold yourself in position, you may want better seat support...
flash968 11-12-2009 05:54 PM
i was merely making reference to as disparate a situation as i could think of
again, i am not arguing the logic or benefit of making the the same - i am only saying that it is better to get the driver secured and thereby more in control of the car - he is the one ultimately responsible for the safety of its occupants - if he gets in over his head and is out of position in the car, the likelihood of an incident is increased
if a choice has to be made whether or not to run with a good driver seat with a harness and a stock passenger seat with stock belts, or both stock seats with stock belts, this is a no brainer - any rule that chooses the less safe setup, no matter what it is, is a bad rule
944Spec_bound 11-12-2009 09:30 PM
?? how did u get that? If the driver seatbelts are 5pt harnesses attached to a rollbar, then the passenger seat belts must meet the same minimum requirement for the driver's belts, which is for the shoulder straps to be attached to a rollbar.
You might get away with just taking passengers in that seat, if you could get through tech and pre grid, but I was told most instructors would decline and had the right to do so.
And hitting the wall at 100mph probably feels the same whether it's racing or DE. It still happens in both and is an irrelevant point in my opinion. Just because it's school, doesn't mean squat and I don't think you should diminish the fact that it's serious business out there during DE's. Everybody drives their cars close to or past the limit in DE, I don't care what they say. They get away with letting you use factory restraints by calling it school, but fact is some of those street cars are turning faster lap times than fully prepped racecars. I've shared the track with many,many,many exotic high performance sports cars or highly tuned street cars in DE levels 1 and 2.
I think I know your what your saying - keep the driver anchored and the passenger is safer. I guess so, but it's like saying,"I'm safe and in control, so you don't need to bother with the extra hassle of buckling a 5 pt harness." But not all incidents are within the control of the driver (mechanical failure, fouled track surface, other driver error) so him/her being better secured has no effect on the outcome. And frankly, I didn't start spinning out in my car until after I was harnessed in, guess I was more careful when my butt was sliding around. People do push harder when they're anchored down better.
No disrespect, but it would haunt me all of my days if my passenger got hurt or worse because I went cheap and didn't give them the same shot at surviving that I had.
You wouldn't let your kids ride in a school bus without the same restraint as the dri......wait......bad example. You wouldn't ride in a city bus without seat bel.....uh, wait. You wouldn't be a passenger on Amtrak without.....oh forget it. Your right, passengers don't even need seat belts at all.
Rasta Monsta 11-12-2009 11:19 PM
+1.
Nuff said.
krystar 11-13-2009 06:03 AM
i think i need to find a track with a downhill straight to get to 100mph. heh
flash968 11-13-2009 06:32 AM
spec - you quoted it differently in the first post than in your second - in the first, it says that they must meet the same minimum spec, but in the second you said they must match - which is it? i flew this by an attorney, and the first one means that the passenger belts must meet the minimum spec allowable in the car, but does NOT mean that they need to meet the spec of the driver belts
everybody needs to stop arguing the wisdom of better gear - that is a given
i am arguing the wisdom of providing a quicker route to a better driver
if these guys are out there driving over their heads, this is the fault of the instructor who allows it and the organizer who set that in motion - the answer is simple - slow them down until they are ready
i want safer drivers out there too - them learning is the only way to accomplish that - allowing them to slide around slows down that process, thereby increasing MY risk factors
i would much rather have 4 20 minute sessions than 3 30 minute sessions if it meant that the novices with no harnesses could be in their own group
fast924S 11-14-2009 08:23 AM
OK. Here is the Deal. Both DS and PS safety equipment must be the same. No need for the same brand just same stuff. SOOO if I have race seat and 5 points on the driver siad then I need them for the Pass side. FOund it all out at the DE event at LRP thursday. It was MAD FUN
flash968 11-14-2009 09:16 AM
see - that's my point - this would prohibit you from learning because you couldn't go out there - that is counter to the very basic idea that improving a driver is the most important factor in track safety
all they have to do is limit the speeds of cars like that - a street car run group is an easy answer - it is a much better solution, which still provides for the driver improvement, without degrading the safety or increasing the likelihood that the mounting points will ultimately wear out due to constant R&R of seats - seat mounting points are not designed to have seats constantly removed and reinstalled
this is clearly a case of what perhaps on the surface seems to be a wise preventative measure actually doing more harm than good
they either need to break out cars with OEM seats and belts out into a group of their own, or outlaw them altogether - prohibiting a car that is safer because it has a better driver seat and harness is just dumb
Rasta Monsta 11-14-2009 09:21 AM
Originally Posted by flash968 (Post 5010633)
Sigh.
Aslet 11-14-2009 09:26 AM
flash968, no offense, but until you take over and run DE for your area and get together with the club lawyers and have to rules changed, it is what it is... The ultimate solution is to just drive a stock car and not worry about it.
Rasta Monsta 11-14-2009 09:27 AM
. . .and this will all have to be accomplished without any working instructors within earshot.
Techno Duck 11-14-2009 09:46 AM
This thread has turned into a good headache inducer. Some 'experts' just don't like to be disproven.
And being in a novice run group or not, some cars are just plain fast and some cars do pop balljoints and break control arms at speed and some cars do blow up engines leaving oil and coolant all over the track. Why settle for safety? I think one point in this ruling is if safety of your passenger and yourself has a price tag then maybe your in the wrong hobby. Not eveyone is going to wear a full fire suit and HANS device (most higher run group drivers do the HANS) but belts and proper seats are pretty basic on the list of safety equipment.
flash968 11-14-2009 09:51 AM
lol - not at all - pca is really the only organization that is of concern here, and not being one to deal with them much anyway (there are so many better organizations out there) it really isn't an issue
it all comes down to money - they want to cram as many cars into a group as possible - this is the primary cause of accidents, not what belts somebody is wearing - this is what will be the next issue for the attorneys
on most tracks there should never be more than 20 cars in a novice run group - it is very easy to show the rate of incline of incident when this is exceeded - frequently this is exceeded by a wide margin - this is dangerous
as for the instructors, as much as they might not like it, the reality is that they all want their own track time, and will sit in the seat regardless so as to get it - all they have to do is slow down the driver, which they should be doing anyway - they would be safer if the driver isn't moving around, whether they are or not - that cannot be argued - the complaint is invalid and illogical
if they are going to limit belts to harnesses, fine - i'm all for safety - limiting just the passenger seat is stupid - allowing stock seats and belts on the driver side, and allowing them to get into unsafe situations is not wise - this is something the attorneys need to look at more closely
safety should never be a compromise - a car with stocks seats an belts anywhere is less safe than a car with at least a proper driver seat and harness - there is no way this can be argued - a car with a novice driver and an instructor is even safer, regardless of how the instructor is strapped in
i've been racing (and even instructing) since before most of the people on this board were born (wow, that hurt just to think about it) i've seen it all - heck, i started when lap belts were fine for driving school - i've watched it progress to the point where it is now - i am all for safety and prepare my cars accordingly - however, the single biggest factor in my safety, outside me and my car, is the skill level of the other driver - the more seat time they can get the better - i'd rather have them get 3 more DE events in than have to pop for a passenger seat and harness
Damian in NJ 11-20-2009 11:28 AM
Yup!
