Mountain Road Maniac
ColoradoSteve's Avatar
Finally figured it out
Thanks to the guys on on this forum, JohnAZ for sending the article on rear suspension ELEPHANT RACING Tech Topic, Polyurethane Bushings and Friction .
It turns out, after going through all the PO's records, he had Weltmeister poly-graphite bushings installed -inner/outer spring plate- and they are most definitely the source of the noise in the rear end. I like the way the car handles , but the noise has got to go! Is there anyway to make these things shut up , or do I have to bite the bullet and replace them with rubber?
'83 944
'87 951- SOLD!
Old 11-23-2009, 10:58 AM
wear ear plugs. no more noises
is there a grease fitting installed?
Old 11-23-2009, 11:09 AM
flash968's Avatar
i had delrin bushings in there, which are typically far quieter than polyurethane (graphite laden or not) - however, they made a racket no matter how much i lubed them - i tried them dry, with lithium, moly, and generic grease - no luck
i then changed to the elephant racing poly/bronze bushings - these are designed to stay lubed - they are grooved for the grease and have a grease fitting, and are shimmed to fit - MUCH better - i do still have one small squeak i am trying to track down on the driver's side, but i don't think it's those bushings - i have taken them apart and refitted them twice with no change - it sounds more metallic than those would make anyway, and it's pretty small, and only on the one side
Old 11-23-2009, 11:22 AM
Ear plugs are fine and I can always crank the stereo up high... noise is still there, though. No grease fittings. I am considering the poly/bronze, not cheap, arrrrgh
'83 944
'87 951- SOLD!
Old 11-23-2009, 11:41 AM
How difficult a job is just replacing the bushings? Not going to mess with the torsion bars if possible...
'83 944
'87 951- SOLD!
Old 11-23-2009, 12:40 PM
Toofah King Bad
Rasta Monsta's Avatar
Removing spring plates? Of course you are!
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 11-23-2009, 01:33 PM
I want my mommy....
'83 944
'87 951- SOLD!
Old 11-23-2009, 04:15 PM
Toofah King Bad
Your mommy can't help you now, boy.
Old 11-23-2009, 04:48 PM
flash968's Avatar
yup - probably better living with it until you're ready to make spring rate changes - no point in doing that job twice
Old 11-23-2009, 04:59 PM
I'm actually starting to like the sound of death metal . totally drowns out those F*****g bushings!
'83 944
'87 951- SOLD!
Old 11-23-2009, 07:41 PM
flash968's Avatar
lol - did too many metal tours - can't listen to it now
Old 11-23-2009, 08:07 PM
