sasquatch's Avatar
I cant believe I am going to ask this.
Do any of the oil stop leaks actually work for a leaking rear main?
I feel dirty even asking that question.
1987 944 NA
190,000 miles
Rotella T synthetic (someone is bound to ask)
The reason I am asking is that the rear main seal is leaking pretty bad. Yes, I know it is par for the course at 190k miles. The problem is that there is nothing else wrong. Clutch is fine, motor is fine, no other need at all for doing the HUGE job of getting to the rear main. I figure that at that mileage I would change the clutch at the same time, but it is not needed now and I really dont have the $$. I do all the labor myself, so that is free.
Sasquatch
1987 Porsche 944
1974 Porsche 914
"Don't retreat, reload." Sarah Palin
Old 11-14-2010, 05:35 PM
ernie9944's Avatar
Sorry to say but adding oil stop leaks won't do nothing to it, if it's like you describe leaking pretty bad ,maybe somebody else migth have a different answer but usually you have to change the RMS nothing else will cure it.And don't forget the oil migth ruin your clutch.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 11-14-2010, 05:47 PM
sasquatch's Avatar
I know anything I do would be a band-aid unless it is replaced correctly. I was just kind of hoping that something out there really worked to soften up old seals and give me a little more time.
Sasquatch
1987 Porsche 944
1974 Porsche 914
Old 11-14-2010, 05:53 PM
That Guy
Techno Duck's Avatar
Switching to a regular dino oil of a heavier weight (15w or 20w50 max) may lessen the leak slightly, but its a band-aid fix at best. Just do the clutch and be done with it. Cost may be high, but factor another 190k miles of trouble free use .
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 11-14-2010, 08:10 PM
smokin_944's Avatar
Ernie and Jon are right. It sucks but there it is. Sorry about that Jay...
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 11-15-2010, 03:43 AM
sasquatch's Avatar
I figured that was my only option, but it never hurts to ask. Thanks guys.
Now to find the best deal on all the parts.
Sasquatch
1987 Porsche 944
1974 Porsche 914
Old 11-15-2010, 03:59 AM
Proprietoristicly Refined
John_AZ's Avatar
1987 944 NA
190,000 miles
Agree with above.
Your labor is free. Here are a few suggestions to save some money.
You could pick up one of those huge garage floor oil drip pans, put on a BIG oil diaper and make sure you stay off concrete driveways.
OR
Parts required:
Clutch disc? Do you still have the rubber center? You can get a disc for about $150-$200 if needed.
Pilot bearing, fork shaft needle bearings, TO guide tube, RMS, exhaust flange gaskets (2)----cheap stuff.
Get the FW resurfaced--$40-50.
About $300-$350. Less if the FW looks OK. You might be able to pick up a used spring clutch disc (parts car or recent wreck)
You can clean up the PP and repack the TO with grease.
Here is a great link on "clutch change on the cheap"
My clutch job, in pictures:
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 11-15-2010, 04:14 AM
