3.0 S2 Ignition Timeing
Hi what s the procedure for setting ignition timeing ? does the dizzy turn like all old cars or is the advance taken car of via the ECU?
Many thanks Mark |
Toofah King Bad
Timing is controlled by DME.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
whats a dizzy?
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Ok thanks lads so i take the dizzy is fixed to end of
the cam pully ,it will only go on one way and is not Adjustable? Provided crank and cam marks are right igniton timeing should be right the dme controls advance? Mark |
Not sure of all the differences between S2 and 968 but this is worth a look.
Clark's Garage Home Page CAM-04, Camshaft Chain and Tensioner Replacement (16V) The Timing can easily be off by 120 Degrees if everything was not set up corerctly. The Rotor is the one that can easily be place in the wront 1/3 turn place. Does the S2 not have the adjustable Cam Wheel for +/- 15 degrees as well? The 968 does. Maybe that came only with 968 motor. PIC of 968 adjustable Cam gear.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles |
Ok thanks ,but i think the 968 has variable cam timing ,i think porsche called it varocam or something like that
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
The S2 also has that adjustment, but don't mess with it, or you'll be sorry. It's a secondary timing adjustment to adjust the timing between the two camshafts on the 16V cars. Single camshaft cars do not have this, obviously. Setting this adjustment properly requires a procedure involving dial gauges. Mess it up and all you'll do is quite noticeably lose a lot of power.
The computer (ECU) dynamically manages the timing according to many variables from sensors and according to data maps. If you want to change the way it behaves you need to put in a new chip. The consensus is that chipping NA 944 for significant performance gains is largely a waste of time (and fuel) however. What are you trying to achieve anyhow? Or are you just curious how these cars work?
Currently 1990 944 S2, Black on Linen, 17" Turbo Twists Last edited by Mark944na86; 01-10-2010 at 05:18 AM.. |
