TSNAPCRACKLEPOP's Avatar
Had cooling problems with your 944 this year??
Just a reminder that if you have a leaky headgasket and have filled up with water only, it's about the time to drain the cooling system, or add some antifreeze for the wintr ahead. even if she just sits this winter.
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 12-02-2009, 01:52 PM
TexasBlake's Avatar
If I had a leaky head gasket I would replace the head gasket.
Old 12-02-2009, 01:53 PM
....and while you are in there...............$$$$$$$$$$$$$$$
Old 12-02-2009, 02:02 PM
agreed
but yea I did just drain a gallon of water and put in straight antifreeze
Old 12-02-2009, 02:04 PM
just adding it will not reach into the heater core, you must run the engine.
Old 12-02-2009, 02:07 PM
well yea. i drove around for half an hour and came back and used coolant tester on it.
Old 12-02-2009, 02:29 PM
Avatar's are to SMALL.
Send a message via Skype™ to cvriv.charles
I have a flush out my cooling system. Any kind of cleaner I could add to clean out my cooling system? I dont have oil or anything else in there,... im just asking. My temp has been flucuating between 2 and 3 at idle almost always hitting 3 but not past. This is new. I figure I would start with a good flushing first.
1986 951 - Wrecked. Being used for engine swap and parts.
1987 944 - SCCA specification track/ street car. Awaiting 951 engine and parts.
Old 12-03-2009, 01:20 AM
the recent threads on " oil in the water"may give you an indicatation on what to use. Also,
Oil cleanup anyone?
Old 12-03-2009, 10:55 AM
DISTILLED WATER is recommenede, due to minerasl electrolysis.
I have been wondering if we should use the Cadillac "PILLS" in our 944 engine blocks. anyone know about this??
Old 12-03-2009, 10:56 AM
