-   -   max psi & what mods done? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/514575-max-psi-what-mods-done.html)
Kiwi944s2 12-08-2009 06:47 PM
There was a company in the UK that took an S2 engine from 3.0 to 3.8 litres and turbo charged it. There was an article in 911porscheworld about it a couple of years ago i think.
J1NX3D 12-10-2009 01:19 PM
Not sure about the 3.8L part but DIVER944 on the rennlist forums had his 3.2L build in a mag. Hes from the UK but I can't remember if it was 911&PW. His car is called Lil: '89 951S Baltic Blue 3.2 litre-
Jon Mitchell 3.2L engine, SPS ballrace turbo, Vitesse Maf & piggyback, TiAL 46mm WG, Greddy EBC
here's a 3.0L turbo registry they started on Rennlist:
3 Liter Turbo Registry - Rennlist Discussion Forums
emoore924 12-10-2009 04:33 PM
Just keep in mind that its all about how much air you *flow* not how high your boost is...
Think about it. Blow hard through a straw. Blow hard through a drain pipe. In which one can you move more air? In which one did you have higher "boost". In which one can you move more air and therefore add more fuel and therefore have more power?
Did anyone read "Maximum Boost" by Corky Bell?
Paulyy 12-11-2009 12:36 AM
yeah you have a point, but im just talking about the standard piping set up with a stock turbo or a small upgrade of the turbo.
wild man 12-11-2009 09:55 AM
If you are are looking for the "cost-free" ticket to 300hp at the crank, just remove the banjo fitting from the charge pipe and stick a short, tightly fitting, piece of vacuum hose into it, being careful not to block the holes near the bolt head (you may want to glue it in). If the ID of the hose is small enough (<2mm), you will see the boost gauge go up to the 2bar mark, and that should net you damn near 300hp.
emoore924 12-11-2009 11:25 AM
Define "cost-free". Does it happen before or after the ka-BLAM part?
cvriv.charles 12-11-2009 02:26 PM
LOL. That was good. Ha.
Paulyy 12-13-2009 03:31 AM
hahaha oh yeah noworries il give that ago tomorrow morning :)
wild man 12-13-2009 03:23 PM
No ka-blam at 15psi, if using good 92 (or higher) octane fuel.
By cost-free, I mean that I think most people would have a short (1/4-1/2") piece of vac hose lying around somewhere. If not, could probably "steal" such a short piece off of the car, somewhere.
If not-want-go-cost-free, you could tap out the banjo bolt and screw in a (2mm ID) carb jet into it, which might cost you a few dollars, or rupels, depending on where you live. You could go higher psi by using smaller jet sizes. But to protect my "reputation" from those who blow up thier engines by doing so, I DO NOT RECOMMEND GOING HIGHER THAN 15 PSI ON STOCK CHIPS. Additionally, I must add that it would probably be a good idea to monitor A/F ratios, and/or install a knock counter.
When I was running with this setup, I was NOT monitoring A/F ratios, and had no issues, other than getting used to having more power - but that thrill kinda fades after a while. And when the pesky little "need-for-speed" issue is back in your face again, taunting you to go over 15psi, please do it "properly". Thank you & good nite. And, what the heck, I might as well add, double H's, while I'm at it.
L8r
