1988 Porsche 944 Turbo S
Bmangler88's Avatar
Starter Wires???
Hey all,
I took my starter off to get to the slave cylinder. Now I am having trouble remembering where each wires connects. There are three wires, a giant black one and a smaller medium sized black one that has a little red wire coming from the same harness. I know where the giant black one goes (positive lead for starter) I know where the little red one came from. But I am having trouble remembering where the other black wire came from. I think it is a ground but i just cant remember where i removed it from. any help????
07 Honda CRF 250X
00 Honda RC51 RVT
96 GMC Sierra Z71
Old 12-12-2009, 02:24 PM
pretty sure it goes on the small post along w/ the red. You didn't remove the solenoid wire did you? (center post)
Bruce P.
2011 Cayman Base, LSD, Sport Chrono.
1988 951 totaled and missed
"You're the best I ever had" --JJ Cale
Old 12-12-2009, 08:50 PM
pretty sure the two smaller wires go together from memory.
Old 12-12-2009, 08:53 PM
That Guy
Techno Duck's Avatar
The two larger (one is from alt. to starter, other is starter to battery) go on the one large stud, the smaller wire (ignition switch signal wire) goes to the small stud.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 12-12-2009, 09:03 PM
and the duck proves me wrong heh.
Old 12-12-2009, 09:19 PM
Bmangler88's Avatar
Duck has it
Techno Duck is right yet again...appreciate the help.
Now I just need to figure out how to bleed the system by myself. Right now the clutch pedal just goes to the floor and stays there.
07 Honda CRF 250X
00 Honda RC51 RVT
96 GMC Sierra Z71
Old 12-13-2009, 11:00 AM
get a powerbleeder
Old 12-13-2009, 11:59 AM
Bmangler88's Avatar
Bleeding the hyraulics
I have tried every bleeding procedure I can find online and I still cant get any clutch pedal. It just snaps to the floor and stays there.
I have a pump similar to a power bleeder but when I try to pump fluid up from the slave cylinder up to the reservoir it wont go, it just pushes fluid out of the connection between the nipple and the hose.
Any Ideas???
07 Honda CRF 250X
00 Honda RC51 RVT
96 GMC Sierra Z71
Old 12-13-2009, 12:21 PM
put a ziptie on your hose on the nipple. clamp it down tight.
u do have yer master cylinder cap open right? hehe
Old 12-13-2009, 12:28 PM
