AFMLink help
in my 952 i have an AFMLink unit with the controller and all. im not sure how to use it to well, ive read the book about 20 times and and what ever i do on the controller my car still has flat spots where it runs lean when i try to take off hard and it does not go anywhere. does any one know how to work this unit or should i upgrade to something else?
cheers. |
Sounds like you need to adjust the response settings - how is yours configured now?
-Rogue |
not sure, the car is at work right now.
you thing you may give me some pointers on which settings to play around with or something like that so i could give something a shot tomorow? cheers |
Its been a long time since I've played with the AFMLink stuff... When you get to your car, find out what your response settings are, and post them here.
-Rogue |
Alright I took a closer look at it and it was set on -20 for some reason. I played with it for about an hour and smoked up the factory -.- but in the end the car is way more responsive then it was :). Thanks for offering your help anyway
Glad you got it figured out ;)
-Rogue |
| All times are GMT -8. The time now is 02:56 PM. |
