On Boost
Paulyy's Avatar
AFMLink help
in my 952 i have an AFMLink unit with the controller and all. im not sure how to use it to well, ive read the book about 20 times and and what ever i do on the controller my car still has flat spots where it runs lean when i try to take off hard and it does not go anywhere. does any one know how to work this unit or should i upgrade to something else?
cheers.
86 952 GTX3076R, M-Tune, eBoost 2, CEP/JME cam, CEP head.
Old 12-12-2009, 06:38 PM
Rogue Tuning
Rogue_Ant's Avatar
Sounds like you need to adjust the response settings - how is yours configured now?
-Rogue
-Joshua
www.RogueTuning.com
Old 12-12-2009, 07:44 PM
On Boost
Paulyy's Avatar
not sure, the car is at work right now.
you thing you may give me some pointers on which settings to play around with or something like that so i could give something a shot tomorow?
cheers
Old 12-12-2009, 09:52 PM
Rogue Tuning
Rogue_Ant's Avatar
Its been a long time since I've played with the AFMLink stuff... When you get to your car, find out what your response settings are, and post them here.
-Rogue
-Joshua
www.RogueTuning.com
Old 12-12-2009, 10:13 PM
On Boost
Paulyy's Avatar
Alright I took a closer look at it and it was set on -20 for some reason. I played with it for about an hour and smoked up the factory -.- but in the end the car is way more responsive then it was . Thanks for offering your help anyway
Old 12-14-2009, 08:37 PM
Rogue Tuning
Rogue_Ant's Avatar
Glad you got it figured out
-Rogue
-Joshua
www.RogueTuning.com
Old 12-14-2009, 08:39 PM
