What type of CV grease do i need?
I have nothing against buying from pelican but I need cv grease right now. What type of grease do I need? I was at a local walmart and decided to see what they had at hand and I saw two types,... I dont remember the specifics but one was all purpose and the other was high performance. I was thinkign high performance but then again I was at a walmart. So I didnt buy any. Going to a autoparts store today. What should I ask for. Thanks.
Checker Auto/OReilly and others sell a toothpaste tube for about $3 per CV.
A standard wheel bearing grease may not be of the correct viscosity or stickyness to hold up and cling to the CV internals. It is such a crappy, dirty job doing all 4 CVs and even using thick vinyl gloves to protect my hands, I do not want to do it over. GL John_AZ |
Oh great. Im looking forward to this now. hey if I have any questions i'll be here in this thread asking. I have to consult the FSM first. I am hoping I can get this started today. if not then tomorrow. it'll probably be an all dayer for me seeing that i have never done this before.
In my other thread you said mark them left & right and in & out. Keeping the in's with the in's and the out's with the out's. I assume I keep the fronts with the fronts and the backs with the backs right? Thanks. |
I used a Moly based grease for mine per Clark's. I bought a small tub of it. There is a fair amount of space in the CVs to fill with grease.
What I use on our cars is Valvoline SynPower grease. It's a high temp, high performance synthetic grease. Valvoline.com > Products > SynPower > Grease SynPower > SynPowerŽ Synthetic Grease
We used it in my kid's 951 when the CV's were clicking really good - like they were ready to die. And now probably at least 2 years later, they're still going strong. What we did was pump grease into each CV joint till it was completely full and came out the other side - probably 200% more than we needed, but grease is cheap and I wanted to make sure we coated everything properly. I probably used more than a half a tube per CV. I was using an air grease gun. I added a hard plastic tube to the end (rather than the standard grease nipple), and slipped that under the boot of each CV and pumped away. It took maybe 20-30 minutes per CV. If you don't have a compressor and an air grease gun, you could do the same thing with a manual grease gun, although that'd probably be a whole lot of pumping... I bought the grease probably either at O'Reilly's or Autozone. http://www.mikepellegrini.com/Graphics/grease.jpg |
If you like mud pies and monkey puzzles, rebuilding CVs can be a lot of fun.
I just used a good moly grease. Remember to flip them on reinstall. |
Damn where can I get a air grease gun locally? LOL. Ok I have an idea of how much of a pain in teh butt this is going to be. Thanks guys.
Failing that, you could probably rent a compressor/air grease gun for not too many bucks. Seriously, 20-30 minutes a side! And I didn't even get greasy...:) I never took my axles off and reversed them - too much hassle - but it ain't a bad idea if your CV's are clicking already. |
I have a compressor. Thats the easy part. See you got yours with your compressor at home depot maybe they have em sold seperately. Harbor freight is a drive for me. so,... we'll see.
I HAD an air powered one, until I forgot to use a regulator on it, and @ 200psi, the air chamber part of it broke right off. Anyways, I recently replaced my CV's, and each one came with a bag of CV grease, which is lighter weight than bearing grease. But just for extra protection, I pumped an extra 25 shots of high temp grease into each of them after putting about 100 miles on them. I used a grease injection needle to poke through the rubber, where it is flat.
On mine, I just jury-rigged the hard plastic tube in place of the grease nipple, then I cut the plastic zip ties on the CV boot. Then I stuck a screwdriver in under the lip of the boot, and wedged the plastic tube in under the lip. Then pump away.
When you're done, reinstall new zip ties and it's good to go! |
I think the best way would be to take the half shaft out. It doesn't take that long and you will be sure to get plenty of grease in there. :)
Finally!!! I got started on my cv joints. The holidays is killing me! And so is my truck! The reason im tryign to get my cv joints done asap is so I can work on my truck. I need something to drive. My truck needs a ton of work! Head work, new heater core, radiator, and new belts. I'd do the water pump but im broke! All this is going to cost more than 800 in parts! I hope I dont have to replace my cv joints because that will really screw me up.
Anyways,... I have trhe cv joints off the car. I am wondering about this one step Im suppose to take via clarks-garage: 5. Use a punch and hammer to tap gently around the outside edge of the CV Joint to separate the collar from the CV Joint housing. It would really help if he had pics. Seriously. Well I took a pic of what I think he's talking about: http://forums.pelicanparts.com/uploa...1261705700.jpg Am I suppose to whack where the yellow arrow is pointing in the direction of the yellow arrow? Is that what he means? If not can someone please tell me. I dont have enough money to experiment. Trial and error. Thanks. |
Correct you are, sir. Should come off pretty easily.
awesome. Thats whats I thought. Now,... I noticed that if i hold the shaft and turn the cv housing back and forth,... i hear clicking. it depends on how the housing is oriented to the shaft. Should there be any clicking at all when I do this or is it suppose to be solid tight? I took a ton of pics. Going to turn this into a tutorial. Emailed texas blake about putting it on his site seeing he's all for tutorials with pics.
HO, HO, HO,
Just another comment on correct grease to use from a very competent sourse, IAN at 944online. The grease needs to be sticky as well as lubricate. http://forums.pelicanparts.com/uploa...1261719097.jpg Shhhh, I hear someone on the roof......................... Happy Holidays to All. John_AZ |
I bought Lucas high temp, high pressure grease which is says is for high speed bearings. I also got a hand pump grease gun with a cool needle attachment. Pics later.
Someone on the roof? Better get the 12 gauge,... |
Should the CV's click when turn the shaft and housing by hand back and forth?
I dismantled one axle. I cleaned all the parts keeping track of what went where and how. I accessed the damage and found some wear marks. Now I am unable at the time to take pics of it because someone(girlfriend) cant find the charger to the camera. And for whatever reason i cant send pics from my phone to my email account.
I wont be able to post pics until maybe the end of the day. I have to wait to get back home ith my girlfriend so she can find the charger. I am impatient and want to know whether or not these joints can be swapped left to right without problem. My gut instinct is telling me no. But I dont know S@#$ about this stuff. Thats $400 dollars right there if they need to be replaced. On top of the 800+ needed to fix my truck. Santa aint given me cash this xmas either. I hope your xmas is turning out to be a lot better than mine. |
Pics are in! Please tell me if I should even bother swapping them side to side. I am tight with money because im actually trying to fix my truck. BUT,... if these absolutely wont last I guess I will have to replace them. If they can be swapped,... do I even need to dismantle the other side or can I just pack it full of grease? They hardly have any grease in them. The pics are bad. I took them with my cell:(
http://forums.pelicanparts.com/uploa...1261759691.jpg http://forums.pelicanparts.com/uploa...1261759698.jpg http://forums.pelicanparts.com/uploa...1261759705.jpg |
